Old 06-03-2014, 07:00 PM   #1
Mator
Mator's Avatar
castle nut size and threads
While repackaging wheel bearings I noticed the threads on the castle nut are shot and I need to replace it. The local parts stores don't carry them and they don't the size or thread size. Can any one help. I want to get a die to chase the threads and a source for getting a new one. Thanks
Mator is offline   Reply With Quote
Old 06-03-2014, 07:46 PM   #2
Mator
Mator's Avatar
Re: castle nut size and threads
Sorry it was supposed to say re-packing.
Old 06-04-2014, 12:21 AM   #3
airdale94
airdale94's Avatar
It should be pretty easy to get a new one. Dorman probably has a replacement. I would try RockAuto.com
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 06-04-2014, 08:25 AM   #4
kcsa75
kcsa75's Avatar
I would think any front-end shop would have an old coffee can full of them.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 06-04-2014, 09:58 AM   #5
mgchevyparts
mgchevyparts's Avatar
1/2 ton? 3/4"-20
Very common Chevy castle nut. Not so common thread, you won't find a die unless you get the spindle rethreading set avail. I don't remember if I bought my die set at Harbor Freight or maybe online, it's a set of dies for all the spindle threads normally used.
Pretty much all Chevy cars and light trucks use the 3/4"-20 nuts, pre-metric.
Dorman 615-065
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 06-04-2014, 10:07 AM   #6
Mator
Mator's Avatar
Thanks guys,
Thats pretty much what I thought. I found a castle nut but will have to order a die. The threads are pretty goobered up and I can get the new nut back on.
Old 06-04-2014, 11:50 AM   #7
Fitz
Originally Posted by Mator View Post
Thanks guys,
These nuts should be grade 8 hardware and the stuff you get from most parts stores today are grade 3 and worse, made in china.
I get mine here: http://www.mcmaster.com/#slotted-nuts/=s9h50p
Fitz is offline   Reply With Quote
Old 06-04-2014, 12:01 PM   #8
tony58
You won't find a 3/4-20 castle nut any where but from a auto parts store. Dorman are correct castle nuts.
tony58 is offline   Reply With Quote
Old 06-04-2014, 12:03 PM   #9
Mator
Mator's Avatar
I forgot to check the grade on the one I found. It was in the self help section at the part store. I had to order a die though.
Old 06-04-2014, 12:26 PM   #10
tony58
Automotive application is the only available, the one you got is good to go. 3/4-20 does not come in different grades.
Old 06-04-2014, 12:29 PM   #11
Mator
Mator's Avatar
Thanks guys. Sometimes the smallest jobs like repacking wheel bearings can go south fast if you dont have the information or the right tools. My new dies will be here tommorow to clean and chase the threads. Thats what makes this site so great. People helping people. Thanks again.
