Old 06-03-2014, 09:08 PM   #1
2112
Cab Trim Install
I am getting ready to paint my cab on my 72 c10 and wanted to paint the cab white. I was wondering how does the cab trim to separate the white from the body color mount? Does it require holes to be drilled for the mounting clips or does it attach by adhesive? Thanks for any and all advice.
1972 Chevy c10
1985 Buick Grand National
1951 Crosley
1941 Cadillac
2112 is offline   Reply With Quote
Old 06-03-2014, 10:49 PM   #2
PowerdbyChevy79
PowerdbyChevy79's Avatar
Re: Cab Trim Install
I too need to know this info......
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 06-03-2014, 11:10 PM   #3
litew8
litew8's Avatar
I think the bedsides (top trim) were the only adhesive applied. The rest are holes. You can see my build for some pictures, though I haven't installed any trim as of yet.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 06-04-2014, 12:03 AM   #4
sameyrasmea72
sameyrasmea72's Avatar
There are about 12 or so studs welded there. a clip mounts on the stud and the trim snaps onto the clip
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 06-04-2014, 12:04 AM   #5
Sklptrljay
Sklptrljay's Avatar
Are you talking about the trim that goes on the back of the cab above the bed?
If so, yeah you drill holes and then install the little clips with rivets.
Edit* Sameyrasmea72 is correct about factory setup with studs. I assume you are adding the trim to a truck that never had the divider.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 06-04-2014, 09:03 AM   #6
2112
Yes, the cab has never had them installed before. Is there a way to use adhesive to put it on? Thanks.
1972 Chevy c10
1951 Crosley
1941 Cadillac
Old 06-04-2014, 11:29 AM   #7
Katrina/10
Katrina/10's Avatar
Not likely adhesive would work due to the design of the clips. They need a stud, or if you really want to you could drill a bunch of holes in your cab and screw or rivet the clips on.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-04-2014, 11:45 AM   #8
Lee H
Lee H's Avatar
The trim and clips with fasteners are sold as a kit. They are easy to put on. The clips use a small screw to attach to the cab and the trim simply snaps onto the clips. I would suggest Mar-K as the brand. You can buy direct from Mar-K and I believe some board vendors carry it. There is a HUGE difference between the off shore VS the Mar-K product.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
