Old 06-03-2014, 11:32 PM   #1
Sodell
Sodell's Avatar
20" Wheels
Got some Boss 20' wheels, I think I am going to have to raise the front up 1 3/4 inches. I cut one coil from the front plus the three inch drop spindles. If I replace the front coil with stock, will that be enough? 295/45/20 and 275/45/20, back are 10" front are 8.5....any help appreciated
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 06-03-2014, 11:59 PM   #2
Sodell
Sodell's Avatar
Re: 20" Wheels
I figured the ones I have now are 235/70/15-28", and these new ones are 275/45/20-29.7 inches. So I am going to have to go up some, Or buy new tires-255/40/20-28"
Scott
Old 06-04-2014, 12:07 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
Re: 20" Wheels
put 35 series tires and call it a day if its not a daily. my daily 2010 is on 275/35/24 not too bad you just feel everything.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 06-04-2014, 01:04 AM   #4
Sodell
Sodell's Avatar
Re: 20" Wheels
Yea, I got the tires and rims together, and the tires are practically new. I would like to use them. Let me know if I am wrong-I just need to raise the front 1/2 of the difference in the height of the tire size, because its from the center of the wheel to the top of the wheel well that I am concerned about...right?
Scott
Old 06-04-2014, 10:56 AM   #5
DREAMER1
DREAMER1's Avatar
Re: 20" Wheels
It'd be much easier to swap tires. If you install a stock spring your front end may look awkwardly too high, instead of looking level or raked
DREAMER1 is offline   Reply With Quote
Old 06-04-2014, 02:02 PM   #6
Sodell
Sodell's Avatar
Re: 20" Wheels
Dreamer, I think you are right. I am going to use some spacers to get up one inch, make sure that is OK, and then either get new tires or swap out the springs for some one inch drop springs. Probably the easiest would be to mount the front tires on the back, and get new tires for the front that are 28". The front tires look brand new, the rear tires are about %75. Not a lot of miles but a few burn outs....
Scott
Old 06-06-2014, 09:45 PM   #7
neatoldstuff
neatoldstuff
neatoldstuff's Avatar
Re: 20" Wheels
I'm running 20" Eagles front and back on my '87 with no clearance problems at all. The truck is lowered 3-1/2" inches up front and 4" inches in the rear. As a matter of fact I used spacers on the rear to get them out closer to the fender openings. Looks better like that. Hope this helps.
neatoldstuff is offline   Reply With Quote
Old 06-06-2014, 09:46 PM   #8
neatoldstuff
neatoldstuff
Re: 20" Wheels
As an added note, I'm running "45" series tires front and rear. I think anything less than that adds too much harshness to the ride. Just sayin'
Old 06-07-2014, 04:28 PM   #9
Sodell
Sodell's Avatar
Re: 20" Wheels
Thanks, I ordered some Belltech 1" drop springs which will give me a total of close to 4" up front, should fix the problem. Seemed like the cheapest way. I put some spacers in the coils up front to raise it 1"and there are no problems with the tires now, and I like the look. I put small spacers in the back as well, the back tires barely clear the inside of the bed!
Scott
