Old 06-04-2014, 09:05 AM   #1
gmhardwick66
horn wire color
what is the color of the actual wire that connects to the horn its self under the hood. The truck I have did not have horn and no wire in the area that horn mounts. I did eventually find an unexplained wire in the drivers fender well harness that is green. My horn button is not wired as well. I have a Grant GT steering wheel that basically has two male spade terminals to attach wires to. any help is appreciated.
gmhardwick66 is offline   Reply With Quote
Old 06-04-2014, 09:28 AM   #2
sboris
sboris's Avatar
Re: horn wire color
Your on the right track. The horn wire is dark green and is located in the same area as the voltage regulator. Should fit a male spade.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 06-04-2014, 11:28 AM   #3
gmhardwick66
Re: horn wire color
Thank you so much. Now maybe you can help me with the rest of my horn install. I removed the steering wheel and I can see the two male terminals on the back side of the after market Grant horn button. Now on the coloum in the mix with the turn signal assembly you can see the brass horn ring. There is also a plunger style stud that is spring loaded to be depressed by the factory style horn button. I have checked voltage and there is 12 volts at the brass ring. The plunger its self does still "plunge properly". My question is how to wire the two terminal horn button to the factory brass ring/plunger? Thanks again for your help.
