06-04-2014, 11:45 AM | #1 |
Decal placement
I am looking for a reference as to where I can put my decals in the engine bay, anyone have info on this or pictures? also which ones were on the 65 c10? Also dont know if this is a 230 or 250 is there a way to tell the difference? Not real familliar with the I6 Thanks as always.http://67-72chevytrucks.com/vboard/a...1&d=1401896613
06-04-2014, 11:57 AM | #2 | |
Re: Decal placement
06-04-2014, 01:39 PM | #3 |
Re: Decal placement
con 2 is the conveyor line that it went down during production. Con 2 = conveyor 2
Good pic of conveyor taking engines to the train for transport c1958
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-04-2014, 01:50 PM | #4 | |
Re: Decal placement
http://67-72chevytrucks.com/vboard/s...540610&page=12
06-04-2014, 01:51 PM | #5 | |
Re: Decal placement
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-04-2014 at 01:57 PM. |
06-04-2014, 04:02 PM | #6 |
Re: Decal placement
i saw it before, i had a change to get the same flywheel as in the pics, but felt $160 for something only i would know is there wasnt worth it
06-04-2014, 04:16 PM | #7 |
Re: Decal placement
Looks like a later 250 to me, which is what a lot of these trucks end up with. Not sure when the change was made, but it looks like your valve cover has a press-fit rubber oil filler plug like my '71 250 does, and my '69 doesn't (not sure of when the change was made). AFAIK, the 63-66 truck engines all had script valve covers with only a twist-in breather and PCV valve hookup (later engines have another hole in the side to pull filtered air from the air filter instead of a breather). IIRC, '75 was when the integral head came out, so just by looking at it I'd guess you have something like a '70-'75 250.
06-04-2014, 04:30 PM | #8 | ||
Re: Decal placement
06-04-2014, 05:41 PM | #9 |
Moderator
Re: Decal placement
06-04-2014, 08:06 PM | #10 |
Re: Decal placement
Thanks, 1963c-10. I really need to go back through the site and redo it when I get back home. I actually had a page of visual clues like that for the 230-250's pretty much finished, but I never got around to putting it up. I'll have to at least get a good inline six ID page like that up soon, considering this is at least the second time that the subject has came up today!
Jay, did someone just stick a later oil filler cap in the place of the breather because they didn't know better, or does your engine have provisions to pull air from somewhere else for the PCV? I thought all the engines with the early script valve covers like that (that's what it is, right?) came with/were supposed to have a breather for the filler cap so that the PCV has somewhere to pull clean air from.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread 1968 Impala 4 door sedan (future driver project) thread Last edited by 66Submarine; 06-04-2014 at 08:14 PM. |
06-04-2014, 08:45 PM | #11 |
Re: Decal placement
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 06-04-2014 at 08:45 PM. Reason: add |
06-04-2014, 09:10 PM | #12 | |
Moderator
Re: Decal placement
