Old 06-04-2014, 01:15 PM   #1
briscuba
briscuba's Avatar
Changing lifters Big Block Chevy
I recently took my (stock) 1970 402 CST/C10 to my local mechanic for a valve adjustment - standard hydraulic lifters. He told me that the #6 cylinder would not adjust. Sure enough, I pulled the intake and found a dead lifter. The others spin, work, and look fine.
I also found some rockers with a bit of wear on them.
MY PLAN: to replace the rockers as a set, same for lifters. I am not pulling the cam, however. I have read that this may be a bad idea..?
I could just replace the one lifter..? Do the set..?
I really just need to get it running again.
Suggestions?
Thanks!
briscuba is offline   Reply With Quote
Old 06-04-2014, 01:32 PM   #2
1968k10blue
1968k10blue's Avatar
Re: Changing lifters Big Block Chevy
I would think, just because of the differences in wear you would want to replace them all, although I don't see it hurting anything to just do the one. I would assume the engine would run pretty rough with only one new and the rest old and worn
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 06-04-2014, 01:56 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Its always been my understanding that you change the cam and the lifters. If you just change lifters they will wear to the worn cam and you really didn't gain anything. Might as well do it right.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 06-04-2014, 02:28 PM   #4
geezer#99
geezer#99's Avatar
It wouldn't be the first or last time only one lifter was changed.
One new one won't effect how it runs. Adjusted correctly it'll work fine.
geezer#99 is online now   Reply With Quote
