06-04-2014, 06:54 PM | #1 |
Engine Swap
I need some input. I have a 1994 Buick Roadmaster with a LT1 engine, the plan was to use it as a donor car for my 1967. What all can I use off of the Roadmaster and how hard is it to do an engine swap and transmission? I was sure if I could use of the chassis? Any help would be great.
1967 Chevy Truck 1969 Chevy Panel Truck work in progress 1971 GMC 1500 all orginal 1972 Chevy Suburban brought from orignal owner 1984 Dodge Rampage 45,000 original miles 1992 Dodge D150 1994 Buick Roadmaster (LT1 Engine) 2000 Chevy Stepside Z71 2008 Honda Element |
06-04-2014, 09:34 PM | #2 |
Re: Engine Swap
Motor and trans are close to a bolt in deal. I say close because of the passenger side motor is like upside down compared to normal configuration. Also the the A/C compressor is down too low to clear the frame rail I think but other than those two small little things it is a straight forward swap and I think you may want to try that gas tank as well. I have read that some guys have used a Chevelle tank on these trucks, and I used a Roadmaster tank[Impala SS I think it was] on my 68 lemans convert with the 6.0 ls1. Oh, yeah the tires will make rollers to use while your working on your project or to do some smoky burnouts with!! Jim
