Old 06-04-2014, 07:28 PM   #1
72duster
51 5 window chevy truck
is there another place to find a vin number the one on truck is worn off i want to buy but it is a big deal in certain state they need to verify in ca.,co. az.
72duster is offline   Reply With Quote
Old 06-04-2014, 09:01 PM   #2
jetnow1
Re: 51 5 window chevy truck
There is no vin as we now know it- trucks were registered by either the engine number
or the body serial number. Unfortunately these numbers were not stamped in multiple
spots. Do you know which number was used on your truck?
jetnow1 is offline   Reply With Quote
Old 06-04-2014, 09:17 PM   #3
72duster
5jph28365
Old 06-04-2014, 10:57 PM   #4
nvrdone
There are some vendors that sell blank ID plates. Why not buy the truck, by a plate & stamp your vin numbers on the plate. Then install the plate on the door post before you have it inspected.
nvrdone is offline   Reply With Quote
Old 06-05-2014, 12:32 AM   #5
72duster
post the name of the binder that's a great idea
Old 06-05-2014, 01:02 AM   #6
iowaboynca
iowaboynca's Avatar
dumb question, but how do you know the serial # if it rubbed through?
iowaboynca is offline   Reply With Quote
Old 06-05-2014, 10:13 AM   #7
72duster
I have title Vin tag is there it is scraped up
Old 06-05-2014, 01:47 PM   #8
nvrdone
Truck shop shows them on page 121. $17.00 ea
Old 06-05-2014, 02:50 PM   #9
mr48chev
mr48chev's Avatar
That beats where I got mine. b http://www.classicparts.com/1951-52-...tinfo/33-013/#
72 Duster that number is stamped in the area next to where it say serial number and should be fairly deep stamping. My original plate is painted over, primered over and generally ragged but you can readily read the number stamped in it.
Here is the info to decode the vin you posted
5 = Kansas city Mo Factory
J = 1951 year model
P = 3100 Series
H = August build month
28365 production number
http://53truck.ez15loan.com/howto/vin.htm
My ongoing truck projects:
Old 06-05-2014, 02:52 PM   #10
jetnow1
The number shown decodes as a 1951 1/2 ton. It is the body serial number which would have been stamped into the Plate as listed above. If this is still with the truck and your
state will use it go ahead. These plates were attached with clutch head screws not rivets.
If this is used to register the truck I would stamp the number into the frame and other
major components to help ID the vehicle in case of theft. Remember this is removable
and therefore easy to change. Better than having it registered by the engine number that
also has usually been swapped out on a 60 plus year old truck.
Old 06-06-2014, 12:16 AM   #11
72duster
that's for all the help
