![]() Join Date: Jun 2014
rear main seal or valve cover gaskets leaking??
I'm getting oil droplets on my driveway....I thought the valve covers where leaking and maybe they are still. They were very loose so I tightened them up and didn't see any more droplets for a few days. I cleaned up the engine below a little so I could see where it was coming from. It does look like the valve covers were leaking or are still leaking. There is oil from the spark plug area all the way down and back...
I did an oil change the other day and wiped the bell housing off real good and the oil pan.....now I got droplets all back on the bell housing. Does this sound like a rear main seal? or? How much should a rear main seal job cost from a mechanic shop? I just need a reasonable ballpark so I know I'm not getting ripped off when I go to get quotes. I'd do it myself, but I don't currently have the equipment or proper space. |
![]() Join Date: Apr 2006
Re: rear main seal or valve cover gaskets leaking??
I think you have to pull the motor to do a rear main seal replacement. I don't think you can get the pan off with it in the truck. The rear main seal is inside the bell housing so the leak should be coming out around the bottom of the engine or inspection cover on the tranny. I went with rubber valve cover gaskets when I built my motor in my Chevelle. No leaks and they last forever. Not cheap though but you get what you pay for.
Kirk 72 Blazer CST 4wd highlander |
I would try replacing the valve cover gaskets before replacing the rear main seal. The gaskets are cheap and easy to replace.
Also, it is very easy to OVERTIGHTEN stock steel valve covers. Especially if they are tightened again and again. The metal underneath the bolt holes deforms and actually causes the valve covers to leak because of loss of clamping force over the entire cover. When you remove the valve covers, lay them on a flat surface and lightly hammer the holes flat if they are deformed. This might do the trick. One other thing to look for is the oil pressure sending unit (or oil line) that screws into the back of the engine block near the distributor. The stock ones are notorious for cracking and causing a leak similar to what you described at the back of the motor and the bellhousing. Just remember these old trucks never were completely leak-free and will always drip. Someone on the forum once said they are just marking their territory. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
![]() Join Date: Dec 2011
I am ditching the OEM bolts going the stud and spreader thingy route on my valve covers.
Try the UV dye, it works great.
#6 | |
![]() Join Date: Oct 2009
It really does sound like a valve cover leak - and Pop is spot on, do the easy/obvious first, because a rear main seal is not a fun, or inexpensive if you let someone else have the fun, job.
If you saw oil up by the spark plug, then the rear main seal is likely not the culprit. The rear main seal is actually enclosed in the rear of the rear main bearing cap. To do it right, the cap needs to be pulled and the crankshaft removed. To do it "sorta right" and cross your fingers, you can leave the crank in, remove the bearing cap, and use a sneaky pete tool to try to snake the old upper seal half out and the new one in, but it's very easy to damage the new seal. Bottom line, it's sometimes best to live with a rear main seal leak until you do a rebuild on the motor. A few drops, while it drives me nuts, isn't sufficient for a full teardown. Pop's description is perfect - flatten the mating surface (gently, and on the edge of something, don't just whang on it with a hammer - it'll ruin the curved edge of the valve cover), especially around the bolt holes because that is where they get distorted the most, get new gaskets, and do not over-tighten them, this allows the gaskets to work on the full perimeter and keeps them from tearing. Hopefully that's your only problem. |
RAT1968 '68 Cab/'71 Parts
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
The rear of the intake manifold could be leaking at the rail to. Some guys use a rubber gasket there, I use a bead of the right stuff sealant along the rails. Look at your distributor base could be a leak there. The oil pressure sending unit or fitting is back there to. The valve covers always leak if they have been on there any time at all. The oil pan gasket could be leaking at the rails. The rear main seal most likely is leaking and the timing cover could be leaking. You can buy the uv kits at any parts store. That works good when you get everything sealed up and your looking for small leaks.
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
Great, thanks guys!
Do you recommend cork or rubber gaskets for the valve covers? Use RTV or not? Also, if the valve covers are warped badly, can you recommend a good set of aftermarket valve covers? |
Watch out for your cornhole !
![]() Join Date: Jun 2003
As far as rear main seals, changing one is much simpler than you're being led to believe. I unbolt the motor mounts and fan shroud, jack engine up and put blocks of wood between mounts and frame stands. From there its just a matter of dropping the pan and doing the seal.
For valve cover gaskets, go FelPro Permadry and forget about it. They install dry, and are completely reuseable multiple times. This gasket I'm holding in my hand has been on two different engines. No sealant, nothing. Just put them in place and tighten the valve covers. They are multi layer rubber, steel composition. ![]() Use good gaskets and proper workmanship and your stuff won't leak a drop. The old yarn about all old trucks leaking is a falsehood. Come to my place and I'll show you a line of trucks that don't leak or seep even a trace amount.
![]() Join Date: Jun 2005
Fel-Pro Permadry is the only way to go. They have built-in torque limiters to prevent overtightening of the bolts. They are very expensive, but as Kevin stated above, they
can be reused several times, and no sealant is required.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#13 |
are these the felpro permadry gaskets your talking about??
http://www.autozone.com/autozone/par...33253_35483_0_ |
#14 |
That's the ones. Painful to buy I know, but they never fail and in the long run are money well spent. Just lay them in place dry, right out of the box and bolt the cover down.
#15 |
cool, what are those extra pcs in the picture on the autozone website??
#16 |
Those are little load spreader plates that you use with each bolt. It spreads the bolt's tension out over a wider footprint on the valve cover to give more even clamping force.
#17 |
Can't remember, I got some at NAPA and some off of Amazon, both worked pretty well. I thought I had a rear main leak but it turned out to be the dipstick provision (long story). It is amazing how oil can be completely invisible until it forms a drop and this can make it very misleading trying to determine where an oil leak is actually coming from. I had drops coming right off the center of my bellhousing, but once I got the UV dye I realized the oil was going down from the dipstick provision, around the oil pan, and forming drops right in the center of the oil pan. My rear main is fine.
#18 |
Like mentioned previously. I've had an engine leak from the back of the manifold by the distributor. I thought it was the valve covers. Make sure and use high temp silicone installed of the gaskets on the front and back of the manifold.
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
#19 |
If there are oil leaks, I'd also look at the front of the engine. The timing cover/crank/damper seal is often toast, and a groove worn in the damper. You can get a sleeve cheap.
If the pan is coming off it makes no sense not to spend another $15 for the sleeve, timing cover, and WP gaskets. Then again mine seemed to be leaking from the front. This was on a 71 Camaro and I popped the dist cap, jacked up the engine and dropped the pan. Pulling the radiator, accessory drives off the engine and so on was probably more work. Cleaning and repainting the parts is the most work. I used colors and finishes that mimicked the "original" stuff so after a few miles it looked the same. But no more oil spots ![]() |
#20 |
![]() Join Date: Jul 2012
The rear main usually show a leak only at the bottom, at the dust sheild and back. If the leak is on the bellhousing, I'm guessing you mean higher up, it's from A. most likely oil gauge line connection on block. B. Intake rear seal (use RTV) or C. disrtibutor (if leak is on passenger side).
