Old 06-04-2014, 10:24 PM   #1
TDWilkes
can you help me decipher this?
Hello all,
I've got a question. Newbee here to this forum. Excited to be here.
I've got this baby of mine that I've owned since '86. I cannot tell what some of these codes are etc. Thought I'd get some of the pros to help out. I'll be posting some pics of my dream soon. It's been in the garage and finally have room to get to it. Gonna try and get it respectable once again. Just never knew about this sticker till recently.
Thank you
Richard
TDWilkes is offline   Reply With Quote
Old 06-04-2014, 11:05 PM   #2
SS Tim
SS Tim's Avatar
Re: can you help me decipher this?
What you want it done for free????? :-)
Welcome to the board.
SS Tim is offline   Reply With Quote
Old 06-04-2014, 11:24 PM   #3
SS Tim
SS Tim's Avatar
CE149S8 _ _ 789 Conventional Cab, 1/2 ton pickup, 1969, St.Louis assembly plant, 8 _ _789 unit serial number
MODEL= CE10934 (Conventional Cab, V-8, 1/2 ton, LWB, Fleetside pickup)
BX2 BODY SIDE MOLDING-WIDE (lower)
B93 DOOR EDGE GUARDS
F51 FRONT AND REAR SHOCK ABSORBERS (HD)
G50 HD REAR SPRINGS
M35 POWERGLIDE TRANSMISSION (2-speed automatic)
P13 SIDE MOUNTED (in-bed spare tire mount, left front)
U63 RADIO PUSH BUTTON (AM radio with push buttons)
Z62 CUSTOM COMFORT & APPEARANCE (mid-level interior trim bench seat)
630 BLACK CUSTOM CLOTH (trim color and type callout)
A11 TINTED GLASS
B85 BODY SIDE MOLLDING (upper/belt)
D36 NON GLARE MIRROR (inside rearview mirror was optional on 69 pickups)
F60 HD FRONT SPRINGS
LS9 350 CU. IN. V-8 ENGINE (3.07 gears)
P01 WHEELCOVERS (full wheel cover option vs a standard hub cap)
R51 8.15x15x4 WW (white wall tires, early 69 offering, 4 ply rated tubless)
Z53 AMMETER-OIL GAUGE (gauges, no tachometer)
517 MAROON (solid metallic paint)
Old 06-04-2014, 11:34 PM   #4
LSUMurse
LSUMurse's Avatar
I am new to this. I actually just started tonight, fooling around with your SPID. It appears that if you go to this site:
http://www.longroof.info/pdf/rpo.pdf
and use the second, third, and fourth digits of the codes, it'll give you the option description. It's sort of generic, but should get you started.
I found it easiest to hit Control + F and use the find function rather than going through and finding the code.
EDIT: SS TIM's second reply wasn't there when I started. Always a day late and a dollar short. BTW, he's pretty much the expert in this.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 06-05-2014, 09:53 AM   #5
TDWilkes
OK, thank you so much SS Tim. That helps out a lot. Seems like an average type everyday truck. Nothing special to it. (truck specs that is)
I've attached a truck pick I took a few months back. Just for giggles.
Have a ways to go, just getting started. Need to see if the engine will still work before I do much else. Drove it till '96 bought it in '86.
Old 06-05-2014, 12:32 PM   #6
SS Tim
SS Tim's Avatar
It was a nice truck when new and typical of a mid-level truck. Power nothing is hard for some people to deal with but is livable.
If it were mine I'd just do a simple back to stock look.
Rebuild the stock engine or use a crate 350.
Swap out the PG for a 200R4 or 700R4 four-speed automatic trans. Since it was built with 3.07s gears a set of 3.73 or 4.11s would give it life it didn't have before with a two-speed. A 5-lug axle swap might be the easiest way to get both lugs and gears.
Add power steering or maybe even a performance steering box. But plan it in conjunction for using full, 71 up (heavier), steering components and disc brakes. Power booster would be a good idea here too. http://67-72chevytrucks.com/vboard/s...68&postcount=4
The maroon poly (metallic) was a one year only color however the earlier 67-68 vermillion was similar. Black interior goes with the maroon very well as about any picture of firsowner69's CST/20 will show.
As you may have guessed the front bumper there is a replacement (71-72). Stock it would have been white on your truck and no rear bumper. I'd add the correct chromed front bumper to carry the theme of the moldings and wheel covers. If you have a nice step bumper (dealer added) I'd keep it.
Old 06-05-2014, 12:39 PM   #7
Fitz
Richard:
you will find this place a very useful resource when it comes to figuring out where your truck was built and the options on the SPID.
http://outintheshop.com/index.html
You can find out all sorts of stuff here, like how many of these trucks were built in 1968 with green paint, hounsdstooth seats and a 396.
http://www.oldride.com/answers/index.html?t=20
Fitz is offline   Reply With Quote
Old 06-05-2014, 01:48 PM   #8
bruceman1968
bruceman1968's Avatar
SS Tim, You did a nice job on that. The added info in parentheses is very helpful. Nice work!
bruceman1968 is offline   Reply With Quote
