Old 06-04-2014, 11:11 PM   #1
school boy
school boy's Avatar
Arrow Help with fuel system
Ok I need a little help before I pull my hair out. Im doing a tpi swap and Im having return line issues. I have the dual tanks with the low pressure efi pumps from factory and an inline high pressure pump. Im was having return line leakage at some of the connector and after using a fuel pressure test gauge found out the fuel isn't returning. It builds pressure up to about 50 psi then rockets to 90 psi. I believe its the tank selector valve. Anybody else have any ideas?
school boy is offline   Reply With Quote
Old 06-04-2014, 11:24 PM   #2
buddy_1
buddy_1's Avatar
Re: Help with fuel system
Could be a fuel pressure regulator problem. Remove the return hose from the switching valve (eliminate the valve) and run it into a gas can. Then check pressure reading again. If it clears up the valve or one of the sender fittings is stopped up or restricted. If it doesn't clear up then it is the pressure regulator or the line to the switching valve.
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 06-04-2014, 11:29 PM   #3
school boy
school boy's Avatar
The fuel pressure regulator on the rail is good and we're getting the high pressure after the regulator too. Is there a regulator in the selector valve too? btw, both tanks and everything in the tanks only have about 300-400 miles on them.
Old 06-04-2014, 11:50 PM   #4
buddy_1
buddy_1's Avatar
There isn't a regulator in the valve. Is the valve new or original?
Old 06-04-2014, 11:58 PM   #5
school boy
school boy's Avatar
valve was put in when the tanks were.
