![]() Join Date: Dec 2002
Brake issue
Recently purchased 71 K-5. as you drive it the brake pedal gets harder to push but the braking doesn't get firmer. 1 out of every 10 times I apply the pedal I feel a shake/vibration in the pedal. No noise but a grind or a growl is how it feels. I have had a few with air in the lines but they had a flat spot in the braking. Could it be a booster issue. I plan on bleeding the brakes asap
Thanks |
Re: Brake issue
Sounds like a booster, but also sounds like a great time to do front wheel bearings, axle u-joints (if needed) and a complete brake inspection. Kind of a gettin' to know you bonding adventure.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
