Old 06-06-2014, 05:30 AM   #1
Skunksmash
Skunksmash's Avatar
Convert to serpentine?
Is it worth it to convert to a serpentine belt system? If so, what are the benefits?
Skunksmash is offline   Reply With Quote
Old 06-07-2014, 11:44 AM   #2
Axle
Axle's Avatar
Re: Convert to serpentine?
Can't think of any benefits.
I've got both kinds, I personally tend to favor the v-belt.
Alex.
Axle is offline   Reply With Quote
Old 06-07-2014, 12:21 PM   #3
Ziegelsteinfaust
Easier to switch belts, and the tension on them is better. The way the belt works for some reason provides more grip. I think it is due to the full width of the belt being on the pulley vs what a V belt has.
Also they worth about 3-5 horsepower.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-07-2014, 01:14 PM   #4
DREAMER1
DREAMER1's Avatar
And looks cleaner
DREAMER1 is offline   Reply With Quote
Old 06-08-2014, 01:47 AM   #5
Skunksmash
Skunksmash's Avatar
There is one advantage to the V-belts. I've had one of them break and was still able to limp home. Not going to happen with the serpentine lol
Old 06-08-2014, 10:46 AM   #6
cadillac_al
Originally Posted by DREAMER1 View Post
And looks cleaner
I'd like to see a clean looking one. Every one I have seen has big jahonkin brackets on it hiding the beautiful engine. I think I may have seen a nice low mount system from March Perf but it was spendy.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-08-2014, 11:59 AM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Easier to convert to a Saden A/C compressor!! I run a serpentine belt system on my ZZ4. Looks modern and works great.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-08-2014, 01:22 PM   #8
squarebodied
serpentine belt has more tension due to the way its routed around the pulleys. serpentine belts don't retain as much heat as a v belt because of the wider and thinner design. serpentine setup doesn't throw belts like the v belt setup.
squarebodied is offline   Reply With Quote
Old 06-08-2014, 02:53 PM   #9
Axle
Axle's Avatar
I've never melted a vbelt.
I've only thrown a vbelt when I ignored it and left it on for longer than I should have.
Serpentine belts are not immune to slipping.
Run what you like.
I drive a square, why would I be concerned about looking "modern"? ;-)
Alex.
Old 06-09-2014, 01:12 AM   #10
Rubble
Run what you like.
Alex.
Exactly......
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 06-09-2014, 06:11 AM   #11
Skunksmash
Skunksmash's Avatar
Run what you like.
Alex.
I was more concerned with better technology than looks. Thus far it seems like it could go either way.
However, they did eventually stop making the Vbelt setup. I would be interested to know why. IIRC, they started putting serpentines even on the TBI trucks of the 90's. Might could use those brackets since they were factory, and not have it looking all cluttered up.
Old 06-09-2014, 08:07 AM   #12
JWall
Frequent Flyer
JWall's Avatar
This is the set up off around a 89 Chevy truck installed on my 76.
- Justin
1 Owner 1976 SWB
Old 06-09-2014, 08:24 AM   #13
bigd65
bigd65's Avatar
They look good, Ive had both.but I aint going through that again.... not that it was a hassell, just just more stuff to spend money on
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 06-09-2014, 09:27 AM   #14
Skunksmash
Skunksmash's Avatar
That is very clean. But what is that think in the middle? Between the AC compressor and the alternator.
Also, is there a kit? Where did you buy your setup? Without having to spend a whole lot. In my experience, junkyards don't really like to sell engine parts. They like to sell whole engines. Most of the time, they won't just sell you parts of an engine. Now that could just be my experiences. But I've gotten this answer before "If I sell you that I'll never be able to get rid of the rest of the motor"
Old 06-09-2014, 09:30 AM   #15
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Easy to do, no belt slippage, and I like the fact that the A/C hoses don't have to cross over the engine. I'm gathering the parts now to do my '87 K5. I put serpentine on all of my square bodies in the past.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 06-09-2014, 09:33 AM   #16
gchemist
gchemist's Avatar
Look for a 92-95 truck setup like this: http://www.ebay.com/itm/Chevrolet-5-...r#ht_22wt_1145
The right bracket on trucks doesn't have a spot for smog pumps. The bracket is cleaner and smaller. V6 systems work but the crank must be a V8. I have a V6 system on my truck. I had to buy a V8 crank pulley to fit my ZZ4.
Old 06-09-2014, 09:34 AM   #17
JWall
Frequent Flyer
JWall's Avatar
That is the belt tensioner.
We pulled the set up of a truck at a pull-a-part salvage yard.
My set up is the 88-89 style. There also is an aluminum bracket available for in the 90-95 GM trucks.
There's more info on serpentine systems here... http://67-72chevytrucks.com/vboard/s...d.php?t=627951
- Justin
1 Owner 1976 SWB
Old 06-09-2014, 09:34 AM   #18
Mr.Chevy4x4
That is the spring loaded belt tensioner. All of the parts are factory GM from late 80's early 90's trucks. 4.3L and small block V8 brackets are the same. Most pull-a-part kind of places don't care what you pull as long as you pay for it.
Old 06-09-2014, 09:38 AM   #19
Mr.Chevy4x4
The setup in my picture is actually from a tuned port camaro or firebird. It moves the tensioner over out of the way of the throttle body inlet.
Old 06-09-2014, 11:21 AM   #20
hatzie
Moderator
hatzie's Avatar
+1 Spare V belts take up a lot of space and there's more than one. Spare serpentine belts are compact and there's only one.
+2 You can swap a serp on the roadside or the parts store parking lot in 1-2 minutes with just a breaker bar and there's no tension adjustment to screw up.
+3 The alternator can be changed in about 5 minutes and again there's no tension adjustment.
-1 The brackets etc are bulky and cover up the engine.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-12-2014, 10:34 PM   #21
squarebodied
Run what you like.
Alex.
heat dissipation of serpentine belts has nothing to do with "melting belts". it is to keep engine temps and under hood temps cooler for more optimal engine conditions. That is why they switched from v-belt to serpentine belt setups from the factory.
Also, if were to do the serpentine swap, you should stay away from the early 90's chevy setups that were a one piece bracket. they have been known to crack and are bulky and heavy.
Old 06-13-2014, 08:49 AM   #22
gchemist
gchemist's Avatar
The engine can look like it's on fire.
Old 06-13-2014, 10:48 AM   #23
Skunksmash
Skunksmash's Avatar
Now that i've had a better look at it, that is some big 'ol bracketry. I could do without the big in-your-face belt tensioner as well. Maybe there is some way around that. Like using a different tensioner somehow.
Old 06-13-2014, 11:10 AM   #24
jjzepplin
jjzepplin's Avatar
Got one of mine on this site with a steering pump,and rebuilt alternator (internally regulated with way more power than stock) for $100 shipped. A new water pump and Sanden air compressor or delete bracket and I am off and running. Sell the old system to recoup costs and I'm even better.
Tensioner - I like it up in front where I can get to it easily in the event I have an issue.
Of course there are all the hidden modifications that go along with modernizing your belt system-Changing the fitting on the new steering pump to the old pump style-easy-setting up your charging system for the internally regulated alt.-a little harder-reverse flow water pump means reverse fan or electric setup-easy to difficult- Afew other issues I may have missed.
That said I love how bright my headlights are(no relays)
love how it doesn't slip belts (auto tensioner)
Much better access to accessories for repair
and probably the biggest hooray for me is---wait for it---
No brackets needed for accessories to your exhaust= easy header installs.
They do HAVE a bracket initially installed on the exhaust but it is not really needed.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-13-2014, 04:54 PM   #25
gmachinz
Cheaper for GM to use cast aluminum brackets than bent/formed steel ones. Serpentine is an overall better design-the level of detail can yield awesome looking accessory drive systems too BTW. I wouldn't just throw them on dirty...
gmachinz is offline   Reply With Quote
