Old 06-06-2014, 08:21 AM   #1
Ironhorse
Ironhorse's Avatar
'99 Tahoe LS Shock ?
Wife and I have a '99 Tahoe LS, bought it used with 67,000 on it. Been quite satisfied with it. So far have changed out the in-tank fuel pump/sender, fuel control spider and basic maintenance items as battery, plugs, wires, cap, etc. Also drained, flushed the Dex-Cool and went back with the standard green coolant at 50/50 mix. Now has 152,000, runs good but the ride doesn't seem as good. 265/75/16's, I air them to 42 lbs. on all four corners, rotate and check balance every 5,000 miles. Has Bilstein shocks on it, not sure of the number. Would these be original as came from the factory? Been looking at getting new shocks, have always used Monroe (Sensatrac) and no one locally has the Bilsteins. Are the Bilsteins that much better of a shock to warrant the differance in $$ ? Tahoe is an LS model with 5.7 & 4WD. Any thoughts, Monroe or Bilsteins ???
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 06-06-2014, 10:17 AM   #2
Daaaanz67
Re: '99 Tahoe LS Shock ?
I think both are good choices. I run Bilstein on my 03 excursion diesel and love the ride compared to the stock junk.
Daaaanz67 is offline   Reply With Quote
Old 06-06-2014, 11:38 AM   #3
Special-Ed
Special-Ed's Avatar
42lbs in your tires? thats about 10 lbs too much....
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 06-06-2014, 11:48 AM   #4
LEEVON
Moderator
LEEVON's Avatar
Take your tires to 34 lbs and remove the bilsteins for some monroe's or OE shocks. Sell the bilsteins if you're having ride quality issues.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 06-06-2014, 11:49 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yeah, what he said. I would come down to around the 32-35 psi range and see how it rides. Too much and the tires act like basketballs and will create a bad ride and overwork the shocks trying to dampen the extra motion.
BTW, I run Bilstein's in everything I can.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-06-2014, 01:02 PM   #6
95 S_Trucker
95 S_Trucker's Avatar
The bilsteins came on a lot of the trucks from the factory, and in my opinion, they are the best shocks you can buy.
95 S_Trucker is offline   Reply With Quote
Old 06-06-2014, 05:04 PM   #7
chevy_mike
chevy_mike's Avatar
BTW, having a good friend who worked at Bilstein for many years, I can 100% tell you that the Bilstein's that come from the factor DO NOT have the same valving as the ones you buy aftermarket.
He did ride tuning for most of the big car companies and he would dial in a set that worked great but the manufacturers wanted stuff more "plush and comfy" so he would do what they wanted. In the end, his valving specs would get turned into the "aftermarket" versions and most always would work better.
Just something to point out.
Old 06-08-2014, 06:08 PM   #8
Ironhorse
Ironhorse's Avatar
For the size tire (265/75/16) the 32-35 psi. seems a bit low but will give it a try. Tread wear has been good, no signs of wear at center as if aired too tight. Alingnment is good, no cupping or scuffing on outer. Will give it a try and lower the psi. down. Thanks.
Wellington, Ks
Old 06-11-2014, 04:06 AM   #9
68c10airstream
68c10airstream's Avatar
Tire pressure is dictated by vehicle weight and load. Look at the driver's door for the recommended pressure. A vw bettle may be 19 psi, and a 1 ton truck 60 psi. Why do we increase rear tire pressure when we are going to put a load in the box? The handle the increased load. I think the bilstiens came on z71 optioned trucks (off road opt).
68c10airstream is offline   Reply With Quote
