Old 08-02-2003, 06:15 PM   #1
treefrog
Lowering rear Coils
What's the best way to drop the rear on a 69/70 coil spring. I only need to go down 1 3/4"
Thanks, TF
treefrog is offline   Reply With Quote
Old 08-02-2003, 06:23 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
TF, you can buy 2" lowering springs or you can buy 2' lowering blocks.You can also get 1" lowering springs(maybe blocks).The advantage of blocks seems to be that they are tapered to the correct driveshaft angle.I would assume you could maybe get 1 1/2" blocks but I don't know where.1 3/4" is prolly going to be custom blocks or a block spring combo.Good luck.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-02-2003, 06:49 PM   #3
treefrog
Close enough. Do you know where I can get the 2"? The stance just isn't quite right. The front is 32", the rear is 33 5/8 at the wheel well. nit picking I admit. Thanks
Old 08-02-2003, 06:49 PM   #4
SEVEND2
SEVEND2's Avatar
use blocks and larger U bolts
Most Auto parts stores like (pep boys, auto zone, etc) have them
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 08-02-2003, 10:02 PM   #5
Low69CST
Make some blocks, get some aluminum that thick, mark for the holes of your u bolts and start drilling. Aluminum should be easy to drill.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 08-03-2003, 01:45 AM   #6
GMC69
GMC69's Avatar
So if going 4" drop in the rear, would it be best to still use blocks or coils???
I do like the fact that the blocks give you the proper angle for the driveshaft, but would only going down 2" affect it that much?
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline   Reply With Quote
Old 08-03-2003, 02:27 AM   #7
chewed 71'er
Treefrog, go ahead and nit pick. Sounds like you don't want your ride in the grass or in the treetops, just a nice level stance. I'd like the same setup. Interested in your recieving more replies.
chewed 71'er is offline   Reply With Quote
Old 08-03-2003, 02:30 AM   #8
BraveDave
I am not sure if you know this or not, but this message board is part of a site that feature a resource page. there are two different companies listed on the resource page that can help you lower your truck to your exact specs. here is the link to the resource page as well as the link to both companies.
this is the main page ( you probably already know this)
http://www.classicperform.com/
http://www.earlyclassic.com/
i bought my springs and lowering coils from early classic and i am very pleased with the results. the ride is much better than stock. i have a 4-1/2" drop in the front and 4" in the back and the ride is outstanding. hope this all helps!
Brave Dave
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible
BraveDave is offline   Reply With Quote
Old 08-03-2003, 05:24 AM   #9
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
hey dave, What kind of tires are you running with 4.5/4 drop? I've got a 4/4 drop now with 255/60/15 front and 275/60/15 rear.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 08-03-2003, 08:47 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I can answer for Dave...
This is a quote on an earlier thread when I asked him the same question...
4-1/2 drop in the front, 2-1/2 " dropped spindles and 2" dropped springs. the back has 4"dropped springs. the wheels are 15 X 8 with a 5-1/2 backspace in the front and a 4-1/2 backspace in the back. 255-50 in the front and 275-50 in the back!
And here's a pic of his sweet truck...
Old 08-03-2003, 01:47 PM   #11
70c10
67-72 Addict!
70c10's Avatar
That is one fine ride!!!!!!!!!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-03-2003, 02:57 PM   #12
BraveDave
Re: I can answer for Dave...
[QUOTE]Originally posted by Tx Firefighter
[/QUOT
Actually, the wheels are 15 X 17's....sorry
Old 08-03-2003, 03:04 PM   #13
Tx Firefighter
Dave,
Now I'm confused....
15x7's or 17s or what?
Old 08-03-2003, 07:01 PM   #14
SEVEND2
SEVEND2's Avatar
Question
I have a 8" gap between the top of the tire and the bottom of the rear outer fender
I want to drop about 6 1/2" of that
so it gives me about (aproximate) 2" gap between the tire and the bottom of the fender
How do i figure that out ito use blocks.
Also can some on please post picks and spec on the rear with lowering blocks. so i can drop this down some
What size block Alumin should i use. ( i have some blocks, just curious on how much i need to cut or ??)
thanks
and stage 2
Old 08-04-2003, 08:55 AM   #15
smokekiki
Mike
smokekiki's Avatar
To go to a 6.5 drop you will need a c-notch in the frame.What size tires are you running.With a 4" drop on my suburban[2" spring,2" block]there is a 1.5" gap between tire and body.275/60-15.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-04-2003, 09:26 AM   #16
Gene
Gene's Avatar
Dave,
15's on the front 17's on the back
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-06-2003, 02:12 AM   #17
SEVEND2
SEVEND2's Avatar
smokekiki - If your response is for my my tire size is (245/60/15 fronts and 295/50/15 rear)
I am not looking to C-notch the frame, I dont want to cover the tires in the fender wells at this time, just looking for a balanced approx 2" gap between them
and stage 2
Old 08-06-2003, 08:03 AM   #18
smokekiki
Mike
smokekiki's Avatar
SEVEND2, 4"-4.5" is about all you want to drop the rear.Any more and you will bottom out against the frame.
