Old 06-06-2014, 10:59 AM   #1
BigDaddyV
BigDaddyV's Avatar
2 piece drive shaft
Heya guys,
I'm trying to figure out where to get a 2 piece drice shaft for my 72 C10 SWB
I have a single but since I'm putting the truck on the ground, (PB Extreme)
I am under the impression that I have to run the 2 piece.
Any help would be nice.
Thanks guys.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 06-06-2014, 11:30 AM   #2
pat english
pat english's Avatar
Re: 2 piece drive shaft
Does it need to be brand new?Can you find a used drive shaft locally?if you get a 2 piece from a longbed you can have have it cut down and rebalanced.That's what i did kinda...
Only the front drive shaft will need to be shortened.The rear is the same for longbed and shortbeds.
pat english is offline   Reply With Quote
Old 06-06-2014, 02:54 PM   #3
lutronjim
I had a 2 piece in my swb 70 and after replacing rubber donut or bearing every couple years my truck mechanic put in a one piece - problems gone. Make your you need e piece.
lutronjim is offline   Reply With Quote
Old 06-06-2014, 04:44 PM   #4
BigDaddyV
BigDaddyV's Avatar
lolife said I did, and I believe him due to the fact he has built a ton of these lowered trucks. I guess I just need to hit the junk yards around here. Thanks for the help.
