Old 06-06-2014, 11:28 AM   #1
60paco
Hiding Wiring Question
So Ive Been Trying To Figure Out How To Hide All The Wires For A Clean Look And I Was Wondering What You Guys All Did To Hide The Wires For The Motor And All The Under Hood Stuff
60paco is offline   Reply With Quote
Old 06-06-2014, 12:22 PM   #2
dantimdad
dantimdad's Avatar
Re: Hiding Wiring Question
Mine isn't done yet. But, the plan is to box in the underside of the inner fender channel at the top and have all the headlight/battery/horn wires hidden that way.
The hood wires are going to be tucked and secured in the lip of the hood and go from the hood to the cab in a loom.
The wires in the cab are going to be hidden by a full under dash panel and mounting the fuse box behind the panel so it doesn't show either.
I'll have pics when I get to that point in my build thread but, it's at least 3 months out.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 06-06-2014, 12:27 PM   #3
60paco
I Ran All My Headlight Wires Through The Frame On My 60, I just Wasn't Sure How To Run The Motor Stuff( Starter, Alternator, Coil, Etc) My Firewall Is Shaved So Im Kinda Stuck Now
Old 06-06-2014, 12:31 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
Since I put a differnt gas pedal in. I used the hole to run my engine wires in. I also ran the headlight wires through the inner fender as mentioned above. The spark plug wires are extra long and run behind the engine and under the exaust. I haven't done much with the hood wires yet but will probably get to it sooner or later.. I should get an updated picture but I wanted to clean up the brake lines first.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
