Old 06-06-2014, 06:59 PM   #1
davepl
davepl's Avatar
Here's a diagram of front to back brake lines
This is for the 72 with discs. Thought it might come in handy for someone. I also added a bunch of details I've had to dig up along the journey. If someone spots anything wrong, please let me know!
On 1/2 ton trucks the front reservoir on the master cylinder controls the front brakes.
One 3/4 and 1-ton trucks the rear reservoir on the master cylinder controls the front brakes (excl vacuum over hydraulic on 1-ton)
Based on my asking and looking, it appears that on the 3/4 ton the line that:
- The rear reservoir port is routed to the front port of the combination valve
- That front port of the combination valve will come out the front-bottom; this is the FRONT brakes
- The rear port of the combination valve is the REAR brakes
- The OD of the front port tubing (front brakes) is 3/16"
- The OD of the rear port tubing (rear brakes) is 1/4"
I got these last two reversed, and discovered that it's pretty much impossible to find a tube nut that will hold 1/4" line and fit that tiny port. So I drilled out the nut to just over 1/4" (just enough for the pipe to barely go through the nut) and the nut was paper-thin. So the front port on the combo valve has to be 3/16"
To reiterate: front brakes 3/16", rear brakes 1/4" (except the crossover pipe on the rear axle, I think that's 3/16" but don't recall offhand).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-06-2014, 08:45 PM   #2
Chvy2NV
Re: Here's a diagram of front to back brake lines
cool.. thanks
Chvy2NV is offline   Reply With Quote
Old 06-07-2014, 08:43 PM   #3
Agent915
THANK YOU!! I am at this stage of my build. I bought a pre-bent factory kit but it didn't come with any diagrams. I'm converting to discs so this is a welcomed help!!
Agent915 is offline   Reply With Quote
Old 06-07-2014, 10:30 PM   #4
davepl
davepl's Avatar
You're welcome! Remember most of my text description is for 3/4 ton, and the diagrams are for 72 with factory discs.
