Old 06-07-2014, 12:05 AM   #1
jmj4
jmj4's Avatar
Crank pulley bolt
Can someone provide the crankshaft pulley bolt size for a 1970 307? Pulled mine few weeks ago while working on pulleys and now can't locate it. Thanks in advance.
1970 GMC Custom 1500 SWB 307/TH350 3.73 Positrac
jmj4 is offline   Reply With Quote
Old 06-07-2014, 01:37 AM   #2
franken
Re: Crank pulley bolt
Any scrapyards in MS?
franken is offline   Reply With Quote
Old 06-07-2014, 02:38 AM   #3
bigmac73
bigmac73's Avatar
i would look on summit racing under the fastners section, or call the tech guys there they should be able to help
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 06-07-2014, 06:49 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
7/16 fine thread for the center one. 3/8 for the three smaller ones around it.
Old 06-07-2014, 09:51 AM   #5
LSUMurse
LSUMurse's Avatar
If you misplaced your washer too, I have an extra I can mail you. They're pretty stout.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 06-11-2014, 01:39 PM   #6
jmj4
jmj4's Avatar
Thanks LSU. I've still got the washer. Pulled the original bolt because I needed a longer one (had to shim pulleys) and I think the darn thing fell under the seat of my daily driver although I can't see it.
