Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-07-2014, 09:05 AM   #1
Witt1962
Wider rear wheel wells.
Just starting at the back of the truck. I know I should stop now.
This truck will need some more tire to hook up the big block.
The plan is to run a ford 9 inch and stock control arms. I will be running at least 29.5x 10.5 slicks or 315/60s on about a 6 inch drop.
What are you guys doing about the wheel well restrictions?
This truck is a 1970 fleet side, wood bed.
Witt1962 is offline   Reply With Quote
Old 06-07-2014, 11:17 AM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Wider rear wheel wells.
Mine are made from two sets of inner fenders cut and welded to make one set that are widened to the frame rails.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 06-07-2014, 11:46 AM   #3
Witt1962
Great idea. I didn't want to weld in a middle strip to the current wheel wells.
Old 06-07-2014, 12:44 PM   #4
vidman
vidman's Avatar
I just used 4 to make 2..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 06-07-2014, 02:53 PM   #5
71Dragtruck
Mine.
Sponsored by:
Hard Candy Customs
Old 06-07-2014, 03:52 PM   #6
tinydb84
tinydb84's Avatar
Love the stock look of those wheel wells!
David
Instagram: myfabguy
Old 06-10-2014, 07:07 PM   #7
scatesracing
Machinist
scatesracing's Avatar
I did the same thing! Just welded two together. Took them all the way to the frame rail.
scatesracing is offline   Reply With Quote
Old 06-10-2014, 08:24 PM   #8
Witt1962
Thanks everyone and thanks for the pictures.
Old 06-11-2014, 11:40 AM   #9
skeeterbug
skeeterbug's Avatar
Ditto took 4 to make 2 lol.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 06-11-2014, 01:50 PM   #10
vin63
It's Better With Nitro
vin63's Avatar
I also used 4 to make two - my originals spliced together with a pair of damaged ones that the owner was going to toss out…
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-11-2014, 02:46 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I won't be running out of width any time soon.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-11-2014, 02:54 PM   #12
Marv D
Registered Truck Offender
Marv D's Avatar
Yup I was going to glue 4 together to make wide ones,, then decided the wood and stock frame was too heavy for my faster faster faster addiction (and lack of motor to make the 'fast' I craved)
So I took the easy, cheap and light way out. Alstons tubs and a bunch of 0.035" aluminum from the local metal shop.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-11-2014, 04:16 PM   #13
vidman
vidman's Avatar
Thats one of the best looking As^,s I have seen in a long time
Old 06-12-2014, 10:42 AM   #14
Hart_Rod
Hart_Rod's Avatar
Here's mine:
Hart_Rod is offline   Reply With Quote
Old 06-15-2014, 03:48 PM   #15
70blackfish
I fit a pair together, fits 29/15/15 tires on 12" wide steel rims...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 08-01-2014, 11:43 PM   #16
MONTE
MONTE's Avatar
I got 29/18/15 on mine.
MONTE is offline   Reply With Quote
Old 08-09-2014, 05:03 PM   #17
vidman
vidman's Avatar
Hey Monte what are you running for back space on the 15s.. any pics of your set-up
Old 08-09-2014, 10:52 PM   #18
ItsRandy
ItsRandy's Avatar
I also spliced 4 to make 2.
ItsRandy is offline   Reply With Quote
Old 08-11-2014, 02:00 AM   #19
ItsRandy
ItsRandy's Avatar
Hey Marv...what is your roll bar/cage good to going through thr bottom part of the cab instead of the top of the cab? What tires are those you are running?
Old 08-12-2014, 06:33 PM   #20
moggey01
Going to fab tubs from sheet aluminum. Have to make them pretty big to clear my tires at ride height.. I think 4inches above the tire is safe . Tire is a 32x17.5 on a 14wide wheel . Tread width is 15 but M/T calls them 17.5. Still using a stock frame but its real close.
moggey01 is offline   Reply With Quote
Old 08-12-2014, 06:53 PM   #21
moggey01
o sorry ,Mine is a stepside, the bed is raised on the frame about an inch 1/2. The steps are moved up on the bed box 1 inch. This gaines over 2 inches with a tall tire (32"). You should have more room with a fleetside I think. The wheel opening is stock ,just lowered the body line back down 1 inch. Ride heigth is 6"
