Fuel line grommet questions......
This is probably a silly question but I thought I might go on and ask. What is the best way to remove the OEM floor grommets (fuel line passes through cab floor) and replace with new ones?
I bought a set of new grommets from Wes at Classic Heartbeat last December. |
Re: Fuel line grommet questions......
Use a big torch!!
Burn em out!! NO!! NO!! Just kidding!! Pry em out with a screwdriver, lube the new ones with a little wd-40 and pop em in. |
#3 | |
http://patperry.net/uploads/blog/200...-fire-blog.jpg Thanks for the advice man. I'll put it to use today. |
#4 | |
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
I just used a chisel and hammer. 1 good swing cut the top off, then poked the rest down the hole with my finger.
