06-07-2014, 02:23 PM | #1 |
Leaky gas cap
I have been having problems with my gas cap, it's not major like gas pouring out, but more like gas drips down the side and I have to wipe it up. I think it's a non original gas cap but I also have the slant 10571 and it does lock or seal if I thighen it all the way. Any one have any temporary fixes and what cap should I get, has to be locking
06-07-2014, 02:23 PM | #2 |
Re: Leaky gas cap
06-07-2014, 08:05 PM | #3 |
Re: Leaky gas cap
I had the same problem and could not find a cap to work with my 72. I finally added a second cap gasket and it solved my problem seals great now.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
06-07-2014, 08:31 PM | #4 |
Re: Leaky gas cap
I stuffed an o-ring under the gasket on my cap to tighten the seal. Works well so far.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
06-08-2014, 06:22 AM | #5 |
Re: Leaky gas cap
The inner lip that has a ( I'm at a loss for words) cam type taper to it has over the years pulled outward so its getting closer to level with the outer edge of the gasket surface. I took a piece of hard wood dowel ( I would have prefurred a brass drift pin or dowel but didn't have one), and began by putting the dowel on the inner edge of the filler neck and tapping it with a hammer slowly working my way around the neck till the gas cap felt right when putting it on. DONT USE METAL, STEEL OR ANYTHING THAT COULD CAUSE A SPARK! Just 2 cents, it worked for me...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
06-08-2014, 11:03 PM | #6 |
Re: Leaky gas cap
Was just noticing the other day on LMC, I think there are 3 different applications. C20, and 2 different year ranges. The locking is for only 1 of those apps.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
06-08-2014, 11:42 PM | #7 |
Re: Leaky gas cap
06-08-2014, 11:47 PM | #8 | |
Re: Leaky gas cap
