What does this statement in the shop manual mean about bleeding brakes?
According to the 72 manual, it says:
"NOTE : The combination valve, located near the master cylinder, must be held in the open position while bleeding. This can be accomplished by installing Tool J-23709 with the open slot under the mounting bolt and pushing in on the pin in the end of the valve. Be sure to re- torque the mounting bolt after removing the tool" So what does it mean to "hold open" the combination valve? Why is it required? Thanks, Dave PS: Please don't say it's not required unless you know why they thought it was required...
#2 | |
Cluster King
![]() Join Date: Nov 2012
Re: What does this statement in the shop manual mean about bleeding brakes?
Another use for the valve is if there is a loss of fluid pressure, front or rear, it will shift the valve and trigger the brake light on the dash. That is one of the purposes of the valve. Hope this helps
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
![]() Join Date: Aug 2008
I was able to use a c clamp to compress the button. In the past I have seen a flat strap with two mounting holes matching the prop valve with an angle bent on the end to compress it.
i too use a cclamp to hold the pion in// it allows you to bleed the rear brakes without the need to change lines or rubber hoses or master cylinder that the guys that dont read the service manual do
Does it matter that my brake light switch isn't on (not grounded)? Or does checking it before/after not prove anything, as it could be sliding around?
Is there a diagram or picture? I'm trying to imagine what I could do with a C-Clamp and my prop valve. Do I remove the sensor on top to access it? Does opening that sensor port allow air into the system? Need more info! Thanks...
#6 | |
Cluster King
To test the brake light function, remove the wire from the valve connector and ground it. If the light comes on the dash when you ground the wire, the light should come on when your valve is shifted. If the light is capable of working but does not come on when it is pluged into the valve, then my guess would be that your valve is OK and not shifted.
Awesome explanation, thank you!
My brake light is functional (comes on when the wire is grounded) and not on (no ground present) at the valve connector, so I think I'm ok.
So does this "button" prevent the pistons from de-centering? In some designs you have to remove the center switch and poke it around with an awl, so that'd be an improvement.
