06-07-2014, 05:57 PM | #1 |
2010 Camaro exhaust manifold
I am needing gaskets for my 2010 camaro exhaust manifolds. The local parts stores are having a hard time getting the right ones. Does anybody have a part number for the 2 hole flange gaskets between the manifold and flange? My flange has a circle groove cut in it and has 2 bolts.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
06-08-2014, 08:07 AM | #2 |
Re: 2010 Camaro exhaust manifold
Here is a pic of the exhaust pipe.
06-08-2014, 09:32 AM | #3 | |
With that groove that you show, it sure looks like it would take a ring type gasket. I searched RockAuto just for grins and they show Fel-Pro 61012 which is a ring type seal. |
06-08-2014, 12:05 PM | #4 |
Thanks dayj1. That felpro 61431 or g1050 is suppose to be the same is what the parts store ordered but it was a bigger diameter than my flange. The bolt holes were to far apart and would not line up. I might try the ring style gasket. I bought these manifolds on eBay and they where supposed to be 2010 Camaro.
06-10-2014, 12:07 AM | #5 |
post a pic of the manifold.
06-10-2014, 07:25 AM | #6 |
That's the ring style gasket
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-10-2014, 11:57 AM | #7 |
Manifold is smooth. I will try to get a pic this evening.
Thanks truckdude. Do you mean just the chrush ring without the 2 hole flange?
06-10-2014, 01:34 PM | #8 |
meowMEOWmeowMEOW
Strange, as different places give different results. Rock Auto only lists 1, the regular crush-fit gasket like some of the trucks use.
But Summit shows the 2-bolt "flat" gaskets with all of their mid-pipe kits.
06-11-2014, 05:11 AM | #9 |
Freakin Awesome!
It should be the GM part number listed earlier in this thread...
http://www.gmpartsdirect.com/catalog/frameset.cfm I'll see if my gaskets have a PN on them when I get home in the morning though.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee |
07-02-2014, 01:00 AM | #10 |
Well I took a shot in the dark and had oreilly's order a 2008 pontiac g8 exhaust manifold to pipe crush gasket and it was the right one. Thanks for all the help guys. Here is the Fel-Pro number if anyone needs it #61519
