Old 06-07-2014, 10:39 PM   #1
davepl
davepl's Avatar
When the carpet doesn't match the drapes, how much torque?
If you're using wheels that are not original equipment for your truck, what do you use for torque specs?
I'm using late-model GM 8-bolt wheels; I believe the torque value on the truck they came on was 140 ft/lbs
The shop manual for a '72 says they should be 75 ft/lbs. It doesn't list anything different for 3/4 ton, one ton, 5 bolt, 6 bolt, or 8 bolt. Just says "Tighten wheel nuts to 75 ft lbs"
I'm using brand new Dorman 9/16" studs and new GM tapered lug-nuts.
I would -think- I would use the value for the wheel & nut combination, but how do I know that's not going to bend the hell out of my rotor? Probably OK on an 8-bolt, but doubling the torque value on a 5-bolt can't be good.
Discuss.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-07-2014, 11:00 PM   #2
leftybass209
leftybass209's Avatar
Re: When the carpet doesn't match the drapes, how much torque?
You have to take in account rotor hub thickness and wheel material. A minimum would be 75 ft lbs. Really i don't remember the last time I've seen a wheel shop torque lug nuts.
leftybass209 is offline   Reply With Quote
Old 06-07-2014, 11:13 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
I would not worry about bending or distorting your brake rotor. They are plenty thick in the hub area.
What you need to be concerned with as far as over torquing wheel nut is stretch. Every fastener has a torque value and when you exceed that torque value, you are stretching that fastener beyond its limit and that will cause a failure. If you continue to torque a wheel nut past its torque spec, it will eventually break the stud or pull the threads from the wheel stud or the nut.
Here is a chart that shows common torque values depending on fastener size.
http://zerofast.com/torque.htm
Hope this helps.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 06-07-2014, 11:47 PM   #4
kwmech
I've been torquing down all my 8 lug stuff to 110. 75 seems a bit light to me for a 9/16 stud. The 1/2 ton, 5 lug 1/2'' studs come down to 90 with the steel wheels
Old 06-08-2014, 04:02 AM   #5
Fitz
Discuss.
I just know this will start an argument BUT I really do not care.
In most cases, the required torque for a fastener holding two mating surfaces has absolutely NOTHING to do with the application. The correct torque is only determined by the grade and diameter of the fastener.
The exception is when those mating surfaces are separated by a gasket (such as a head gasket) then it is the design of the gasket and deformation limits of the gasket that determine the pressure needed to seal the two surfaces independent of the strength of the fastener.
It doesn't take a rocket scientist (but I am one) to figure out that the "Torque to Failure" bolts used by GM on the LS engines for things like the Balancer Pulley, Cylinder Heads and other places are also exceptions to this rule but torque for those fasteners is specified as an initial torque setting and a final torque angle as measured by a torque angle meter.
That's it. End of Story. So, for wheel lugs look up the diameter and thread pitch in Machinery's Handbook and use the torque values specified there; or guess 75 ft Lbs. which is the appropriate value for a 1/2 in Grade 5 fastener.
If you don't have a copy of Machinery's Handbook you can download a PDF here:
http://www.varjepc.com/admin/upload/...20Handbook.pdf
Fitz is offline   Reply With Quote
Old 06-08-2014, 06:51 AM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
"I just know this will start an argument BUT I really do not care."
It is only my opinion that you can not argue with fact. The other exception to the rule is pre loaded bearing torque but that is a whole different topic.
Good points on your post.
Old 06-08-2014, 09:30 AM   #7
Kennuck
Kennuck's Avatar
Good points Fitz, I agree the Machinery handbook is a great resource. By the way those LS bolts you are referring to are "torque to yield" not "torque to failure"
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 06-08-2014, 10:17 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Be careful what you read and what torque values you use. You may be torquing a metric fastener with the old SAE thread value, or Vice Versa. The thread pitches are different and you may indeed be tightening a fastener "to failure". Use the values you find that are appropriate for the year parts you have.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 06-09-2014, 01:06 PM   #9
davepl
davepl's Avatar
Ah, but there's the rub. I'm talking about mismatched parts, so which parts? Rotor? Hub? Lugs? Nuts? Wheels?
Old 06-10-2014, 08:59 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
You need to rely on the information given for the nuts and studs. You aren't going to crush the wheel metal. If you are using metric studs, they tend to run coarser than SAE, that's why the higher torque on the newer fasteners.
~Steven
Simi Valley, CA
Old 06-11-2014, 08:02 PM   #11
davepl
davepl's Avatar
Great thinking on the metric thread pitch increasing the torque.
I remember as a teen that I always thought if a shop used an impact to put my wheels on (without a torque stick) that it ran the risk of bending my rotors?
Do you think that's an urban legend, or can it happen?
Old 06-11-2014, 08:39 PM   #12
Fitz
If your thread pitch gauge doesn't read correctly get one that does. if you don't have one and you just guess about pitch you deserve all of the failures you encounter. Unified National Coarse and Unified National Fine threads have not changed in 90 years so changes to the standards aren't a problem. The international standard for Metric threads ISO 262:1973 was universally adopted in 1973 and has remained un-ammended.
Old 06-11-2014, 09:13 PM   #13
terry b
terry b's Avatar
You guys crack me up.
terry b is offline   Reply With Quote
Old 06-11-2014, 09:18 PM   #14
71swb4x4
71swb4x4's Avatar
I am posting simply to drop the average IQ in this thread down a few points.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-11-2014, 09:25 PM   #15
terry b
terry b's Avatar
Though i do hate to get my nuts streched.
