Old 06-08-2014, 12:36 AM   #1
goochy
74 K5 Low Bucket driver seat ( need Help )
Driver seat has 4 bolts on front of seat where seat bolts to floor , 2 bolts closest to center console ( on rear of seat ) , can anyone tell me what 2 are closest to door ( rear seat bracket on front driver seat ) . Mine has 2 studs sticking up from the floor , but they are not tall enough to go though the seat bracket where it bolts to floor . How do I get threaded studs out ? when I bought it , the seat was not bolted down ? How does a 74 front bucket seat bolt down ?
goochy is offline   Reply With Quote
Old 06-09-2014, 10:23 AM   #2
lowrodderchev
lowrodderchev's Avatar
Re: 74 K5 Low Bucket driver seat ( need Help )
Can u remove the studs? My just has bolts that go through the floor board (floor board is threaded)
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-09-2014, 11:25 AM   #3
goochy
I am going to try heat and vice grips
Old 06-09-2014, 11:32 AM   #4
lowrodderchev
Pb blast better than wd 40 spray it leave it I've used it on bolts rusted in exhaust manifolds
Old 07-03-2014, 12:07 AM   #5
swissarmychainsaw
All the seats should be bolted in from the top.
Having "studs" sticking up only makes sense if the bolt broke, or someone "customized it".
Should be 1/2" Coarse thread If I remember.
Remove the seat and put two nuts on the stud to help remove it.
+1 On PB-Blaster. Spray, soak wait, spray, soak, wait over a couple of days.
(use a breaker bar)
If that does not work (and it should) then apply heat.
swissarmychainsaw is offline   Reply With Quote
Old 07-03-2014, 07:08 AM   #6
goochy
Thanks !! I have not had time to mess with it yet . LONG list of things to fix .
