06-08-2014, 02:43 PM | #1 |
4l60e slip yoke
Finally started working on the connecting the driveline and realized the slip yoke I have (TH400) is different from the 4l60e. I have the stock driveshaft, anyone know what the u joint sizes are or would it be best to hit the part store and verify prior to ordering a new yoke?
06-08-2014, 04:47 PM | #2 |
Re: 4l60e slip yoke
Just get one for a 350 turbo or 700r4, they're easy to find.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-09-2014, 12:52 AM | #3 |
Re: 4l60e slip yoke
Thanks, found a few online. Would it be 1310 or 1350? Does that even matter?
06-09-2014, 09:56 AM | #4 | |
Re: 4l60e slip yoke
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
06-09-2014, 10:39 AM | #5 |
Re: 4l60e slip yoke
I have a nearly new 1330 rearend yoke, let me know if you are interested.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-11-2014, 03:57 PM | #6 | |
Re: 4l60e slip yoke
06-11-2014, 04:57 PM | #7 |
Re: 4l60e slip yoke
I will be working on the drive line soon. I called a local drive shaft company and they said the slip yoke should only go in about 3/4 of an inch?.... Is this what everyone is finding??
Trying to get thru my LS swap |
06-11-2014, 05:22 PM | #8 |
Re: 4l60e slip yoke
ummm mine goes in almost 2 inchs 3/4 inch is nothing
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-11-2014, 07:23 PM | #9 | |
Re: 4l60e slip yoke
That is not the way to measure, You measure from the end of the extension housing to the center of the rear U-joint, And the Shop figures out everything else. http://www.dennysdriveshaft.com/app/...iagrams/b.html |
06-12-2014, 03:01 AM | #10 | |
Re: 4l60e slip yoke
06-12-2014, 07:26 AM | #11 |
Re: 4l60e slip yoke
Yes my drives haft shop wanted from the fatherest point on the Tran which was the out put shaft
06-12-2014, 03:48 PM | #12 |
Re: 4l60e slip yoke
OK, I so I. Measure from the end of the transmission to the differenttial where the u joint fits in??
