06-08-2014, 05:49 PM | #1 |
What rear ends will fit a 72
I put a 700r4 in my 72 C10. It has 3:08 gears in the rear end. Looking to change it to 3:73. What year truck rear ends are the same as a 72 with coil springs?
06-08-2014, 07:17 PM | #2 |
Re: What rear ends will fit a 72
the 71 and 72 are 5 lug and the same width
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
06-09-2014, 05:24 AM | #3 |
Thank you.
06-09-2014, 08:08 AM | #4 |
The 67 through early 70 rear ends will fit, but they are a little narrower and are 6 lug. They do make 5 lug axles that can be swapped in. You can also use later model truck rear ends that have 5 lug patterns, but if you have coil springs you would have to weld perches on.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
06-09-2014, 03:31 PM | #5 |
why dont you just change the ring and pinion?
06-09-2014, 03:48 PM | #6 |
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
06-09-2014, 03:58 PM | #7 |
06-09-2014, 04:22 PM | #8 |
67-68 allow you to have extra room for tubs and larger tires, just my 2cents.
NO CHARGE !!!! |
06-09-2014, 06:00 PM | #9 |
You will have to get a different carrier too, and while your doing it might as well go posi, right?. With parts and labor it starts creeping up towards a grand. A decent used rear end can be had much cheaper.
I'm in the same boat right now, I'm looking for a 3.73 rear end.
06-09-2014, 11:39 PM | #10 | |
06-10-2014, 12:20 AM | #11 | |
I was looking online myself tonight and saw that they make 3 series 3.73's. I never knew that, that is a great option.
