Old 06-08-2014, 11:02 PM   #1
2112
Wiring Harness?
I am installing all new wires in my truck and was wondering which brand to get, a painless or autowire? I have heard good things about both and they are comparable on price. I also would like to know if they work with HEI or if I need to make modifications. Thanks for the help.
1972 Chevy c10
1985 Buick Grand National
1951 Crosley
1941 Cadillac
2112 is offline   Reply With Quote
Old 06-08-2014, 11:35 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Wiring Harness?
I like M&H. They will make an HEI harness if you want, also internal regulator if specified. Original style Packard connectors in the right colors and exact lengths as OEM. American-made and the technician who builds the harness puts his own name on his work. Not cheap, but comparable.
Since I never used American Auto Wire or Painless it would be unfair to knock them, but I have had good results from M&H.
Old 06-09-2014, 07:01 AM   #3
truckdude239
truckdude239's Avatar
Re: Wiring Harness?
I used American auto wire couldn't be happier
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-09-2014, 08:33 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Wiring Harness?
AAW or M&H. NOT painless.
Tom Vogel is offline   Reply With Quote
Old 06-09-2014, 10:07 AM   #5
BC10
BC10's Avatar
Re: Wiring Harness?
M&H almost identical to stock. Installed all my dash wiring with no problems.
BC10 is offline   Reply With Quote
Old 06-09-2014, 12:11 PM   #6
JustLiveIt
JustLiveIt's Avatar
Re: Wiring Harness?
Agree with Tom Vogel. Use American Autowire or M&H. You spend a bit more to get the stock style harness with the stock plugs, etc. but the installation will go much easier. I used American Autowire that I got from Classic Industries and everything worked the first time. It was as close to plug and play as you will get.
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 06-09-2014, 12:59 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Wiring Harness?
I used M&H for all my wiring and it is all "plug and play" with the correct factory clips, connectors, retainers and tape. Also the engine harness, and front light harness included the factory style plastic wire channels. Good quality stuff.
I got mine from Wes at Classic Heartbeat (site sponsor).
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-09-2014, 02:58 PM   #8
long67
long67's Avatar
Re: Wiring Harness?
Also used M&H no problems.Going on 14 years since install.
Mark
67 c20 custom camper
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
long67 is offline   Reply With Quote
Old 06-09-2014, 03:42 PM   #9
csfields
csfields's Avatar
Re: Wiring Harness?
Just finished mine. Get the american auto wire kit. Plenty of wiring, you get the dimmer switch, headlight switch, ignition switch, key. Real nice easy to read instructions. Very happy.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 06-26-2014, 11:19 AM   #10
engineer_gregh
engineer_gregh's Avatar
Re: Wiring Harness?
Hi Casey, mind if I ask how long it took you to install the kit? Did you replace all the harnesses? Thanks
engineer_gregh is offline   Reply With Quote
Old 06-26-2014, 01:34 PM   #11
csfields
csfields's Avatar
Re: Wiring Harness?
Yes, I purchased the american auto wire kit and replaced the entire harness. It was my first time rewiring an entire truck, and I must say it was very easy. Everything worked on the first try which astonished myself. As far as time? Couldn't really say, I know I could do it quicker a second time around. I really just took my time so I didn't have to redo anything. Just study the directions before starting and compare them to all the connectors, etc. It was actualy enjoyable and learned alot during the process. I would say it could easily be done over a long weekend. The kit came with everything needed. I think the only thing I had to purchase was the main ground strap and positive lead from the battery and a cigarette lighter, glove box light and dome light, which just because of cosmetic reasons. I do recommend purchasing new light sockets for frt turn signals, back up lights and brake lights. Just to make sure every thing is fresh. Mine were pretty nasty. The kit comes with the side marker sockets. The american auto wire kit, comes with plenty of options too. Third brake light, electric fan, different style columns, aftermarket gauges, etc. I stayed mainly stock, so I didn'y need them, but nice to know I have options down the road that are there if needed. It also had plenty of wiring and extra terminals. Anyway, I hope this helped. I know I am rambling.
I see your from Smyrna. I visit the Nissan plant frequently as we (Akebono) supply them with brake calipers. Nice area. I am about 2.5 hours north of you.
Thanks,
Casey
Old 06-26-2014, 05:34 PM   #12
engineer_gregh
Re: Wiring Harness?
Casey, next time you're in town reach out and say hello. We have a hotrod club that meets every Friday night in Murfreesboro, typically a couple hundred cars and trucks show up. Thats only 6-8 miles from the plant. I live about 2 miles from the plant. Thanks for the response, I may tackle updating my harness this fall.
Old 06-26-2014, 06:28 PM   #13
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: Wiring Harness?
about the best price i could find with just a quick search is from Yogi's Ebay store for the 67-68 Classis Update Series
http://www.ebay.com/itm/American-Aut...-/331196435772
US $500.65 & free shipping
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 06-26-2014, 07:09 PM   #14
Posted
Posted's Avatar
Re: Wiring Harness?
Originally Posted by truckdude239 View Post
i used american auto wire couldn't be happier
x2
Posted is offline   Reply With Quote
