Old 06-09-2014, 05:02 AM   #1
quickchevy
quickchevy's Avatar
Replacement Keys
My keys for my 66 truck were stolen.Whats my best option.
quickchevy is offline   Reply With Quote
Old 06-09-2014, 05:11 AM   #2
Dismas
Re: Replacement Keys
If your door and ignition use the same key, then take apart the door handle and go with the lock cylinder to a locksmith, they can make a key for you.
If not the same, it will be difficult, to say the least, to get the lock cylinder out of the ignition, but worth a try.
Failing that, you can get a whole new ignition switch, with lock cylinder and key, and replace the whole unit.
Dismas is offline   Reply With Quote
Old 06-09-2014, 08:01 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Change your keys!
If your truck is open, get a locksmith to change the door key asap. then order new ignition switch,lock cylinder and door locks from your favorite parts store.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-09-2014, 08:18 AM   #4
63 & 64 Bowties
and a few others
member LockDoc, a locksmith, just did a post about this:
http://67-72chevytrucks.com/vboard/s...d.php?t=630654
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 06-10-2014, 01:33 AM   #5
old cool
Got a question or two that would fit under this thread. Hope that's ok?
My door handle is aftermarket (new) and the truck came without a key. When I push the door handle down in the lock position from inside, it seems stiff and hard to lock. I can't imagine a key lifting the handle. Is this a common problem? It seems obvious that I will need to get the handle moving smoothly before even bothering with a key? And since I will need to get the mechanism operating more freely, is that just a matter or removing the door panel and spaying some silicone or lithium on the handle guts. FYI: 66 GMC
old cool is offline   Reply With Quote
Old 06-10-2014, 02:38 AM   #6
oem4me
I can't say exactly what's keeping your inside lever from working freely, but even if it were, the outside push button will not lift the lever. A key will NOT let you in if the inside lever is down.
Old 06-10-2014, 02:50 AM   #7
66Submarine
66Submarine's Avatar
X2; all my trucks have a firm detent or whatever IIRC. The keyed lock is a separate mechanism.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 06-10-2014, 04:31 AM   #8
tincan1966
tincan1966's Avatar
The only function the key in the outside handle does is prevent the button from being pushed in. It is not connected to the lock mechanism of the latch at all.
Secondly , if you were to put the inside lever in the "lock" position and then shut the door, it will kick the lever back to the middle position. This is, of coarse, IF it is assembled and working correctly. These trucks are designed to not allow you to lock your keys in. In all actuality, the inside lever should not be in an "up" or "down" position. I believe they should be pointing mostly down and be operated either forward or rearward. This is why some worn latches may lock the doors when they are shut firmly, the weight of the lever handle causes it to drop and lock the doors.
tincan1966 is offline   Reply With Quote
