Old 06-09-2014, 02:20 PM   #1
70's luvr
Should this slide right in?
Pulled it from a 1980 Chevy 3/4 ton (couldn't have been a 1ton could it?) Owner is getting me the vin# today. Sway bar is the size of my wrist
Mine is a 1970c 2500 with power drum. Do I realistically need to pull my motor to do this ? The truck we pulled it from had the motor and the front clip removed.
70's luvr is offline   Reply With Quote
Old 06-09-2014, 02:25 PM   #2
bonnieclyde100
Re: Should this slide right in?
id say yes im pretty sure the motor mounts are attached to that cross member. unless you can support the engine and chassis separately.
bonnieclyde100 is offline   Reply With Quote
Old 06-09-2014, 02:29 PM   #3
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
chain up the motor/tranny with a hoist and just a jack to drop the cross member down and the new one back up. Wont have a terrible amount of room with the hoist there, but it can be done. If you have a engine sling available, even easier.
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 06-09-2014, 04:47 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Bolt in deal. I had to re-drill one hole and enlarge another...
LockDoc
Leon
Old 06-09-2014, 04:56 PM   #5
Kennuck
Kennuck's Avatar
Ha, I didn't know the later 3/4 tons still used the screw in control arm bushings. Since this is the case what's the advantage of swapping out the whole cross member? Why not just swap the control arms and spindles, brakes etc onto your cross member.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 06-09-2014, 06:42 PM   #6
PowerdbyChevy79
PowerdbyChevy79's Avatar
no you dont have to....but it will be a whole lot easier if you did..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 06-10-2014, 06:31 AM   #7
70's luvr
Thanks for all the input guys! Will tearing into it this weekend.
Old 07-08-2014, 02:40 PM   #8
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Did this a year ago without pulling the motor.
http://67-72chevytrucks.com/vboard/s...d.php?t=587600
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 07-08-2014, 02:50 PM   #9
70's luvr
Thanks!
