06-09-2014, 05:14 PM | #1 |
Do I need this for my LSX swap?
Doing a LS2 from a GTO with 4L65E auto trans..... Just seeing if I needed this bracket?
65' Chevy C-10 Shortbox |
06-09-2014, 05:15 PM | #2 |
Re: Do I need this for my LSX swap?
06-09-2014, 05:17 PM | #3 |
that bracket is for a auto column shift
06-09-2014, 05:21 PM | #4 |
Yeah, that sounds right to me, but will I need it?
06-09-2014, 07:38 PM | #5 |
That would be a big NO you don't NEED it. I used a Lokar column shift linkage assy knock off eBay. The all thread rod supplied wasn't long enough to fit our truck so I bought a length of all thread from the local hardware store and then slipped a section of 5/16" polished stainless tubing over the all thread (left over scrap from my work).
Here's a couple of pics if that helps any. |
06-09-2014, 08:36 PM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
I did the same this as 64shortbox.^^^^^
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-09-2014, 10:10 PM | #7 |
I made my own out of the 3 spd manual column (VERY similar to the auto)
Simply 3/8" HRS rod...... a torch and vise/press..... and then threaded the end for the ball end joint. Made my own linkage arm tho too. (OLD/Clocked New)
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 06-09-2014 at 10:18 PM. |
