06-09-2014, 06:17 PM | #1 |
Driveshaft Question
I searched and didn't come up with the exact answer I was looking for. I am converting my engine and transmission in my 64 LWB to an LS/5 spd. The factory driveshaft is too long. I measured and it seems like the driveshaft from a colorado would fit, but it is a 1 piece. My question is, Why will a 1 piece driveshaft not work? Will it hit the crossmember during suspension travel? If so, will a porterbilt crossmember fix that?
James
'64 C10 Build Officially LQ/NV3500 swapped and Bagged |
06-10-2014, 12:43 AM | #2 |
60-66 Nut
Re: Driveshaft Question
Having a driveshaft shortened is relatively inexpensive. But if your current driveshaft is the light duty assembly, I would definitely change it to something else. I can not answer your question about a one piece in a LWB, since I would not convert a long bed, I would stay with a the HD 2 piece. Many others will disagree with me.
You may get lucky and the Colorado driveshaft may work correctly.
