06-09-2014, 06:45 PM | #1 |
Ifs crossmember
I'm installing a speedway mustang 11 ifs on my 53 gmc 1/2 ton long bed and according to instructions they say to keep the truck the same height and rake and level frame side to side,before installing crossmember but with all old suspension and front end removed it's hard to determine height and rake. I still have rear tires on truck .Also do you mount crossmember with same rake/slope as frame any help maybe floor to frame height .
06-09-2014, 08:46 PM | #2 |
Re: Ifs crossmember
Critical placement is crossmember and frame axle centerline. Also is the hat placement. Just use their dimensions.
06-09-2014, 08:50 PM | #3 |
Re: Ifs crossmember
so I should just make it plum to frame level side to side and of course center line dimensions
06-09-2014, 08:53 PM | #4 |
Re: Ifs crossmember
Generally yes. Measure back from the hole in the frame like in the directions and center the crossmember front to back that distance. No need to trim the crossmember. Position the hats front to back as in the directions. That's it
