Old 08-03-2003, 12:42 AM   #1
GMC 3
CV joints??
Im not exactly sure a CV joint is.
GMC 3 is offline   Reply With Quote
Old 08-03-2003, 12:47 AM   #2
Alexis
Member since 2000
Alexis's Avatar
hmm, CV boot? it what new trucks have in there IFS and most imports that have front wheel drive. I'm guessing.
Alexis is offline   Reply With Quote
Old 08-03-2003, 12:47 AM   #3
Blue_71
Bloo
Blue_71's Avatar
its the joints on the axle shaft from differential to hub, theres 6 bolts holding it to the differential... you have to replace the whole shaft
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 08-03-2003, 12:49 AM   #4
Blue_71
Bloo
Blue_71's Avatar
also, forgot to mention, the reason i say thats your problem is because when they go bad bearings fall out and they start popping
Old 08-03-2003, 12:56 AM   #5
Alexis
Member since 2000
Alexis's Avatar
haha todays not my day with cars....
Old 08-03-2003, 01:40 AM   #6
jcueckert13
jcueckert13's Avatar
cv=centrifical velocity joint depending on the use they can resemble two u joints connected together there purpose is both as a pain in the ass to repair and to give you tighter driveline angles. most older jeeps have a cv joint on the front drive shaft where it goes in to the T-case
jcueckert13 is offline   Reply With Quote
Old 08-03-2003, 10:41 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I respectfully disagree...
We are talking about two different things here.
CV=Constant Velocity joint, and a double cardan joint. They both transmit power at greater angles than u-joints, but they are different.
Blue_71 is right about cv joints on drive axles. Check this out http://images.google.com/imgres?imgu...UTF-8%26sa%3DG . (Sorry, I don't know how to post the link with only a word or two).
My K20 has a double cardan joint between the t-case and front driveshaft. It resembles 2 u-joints as an assembly, as shown here http://images.google.com/imgres?imgu...UTF-8%26sa%3DG
Hope this helps...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-03-2003, 12:48 PM   #8
Blue_71
Bloo
Blue_71's Avatar
that first link stocker posted shows what i was talking about for the IFS trucks... weve found those big ball bearings in our driveway before... never had much luck with them on the 89 (so far weve replaced the shaft on each side twice)
the way you replace it, take off the wheel, take off the big nut in the center of the hub (youll need to hold the hub somehow), now go back to the differential and start taking out the 6 bolts (easier to do this now so you can roll the shaft by rolling the hub) once you get those out you should be able to monkey the shaft out around the a-arms
