Header bolts size
Ok one of the 100 little things I need to do is find some header bolts as I lost the manifold bolts when they were taken off and for some reason I cant seem to find them or at least decently priced ones. I have found some online but they dont say the size or thread pattern, I know they are metric Im thinking M8x1 or 1.25 does anyone know the size I need for my 07 5.3 ? and where to go to get some ? I went to the local Home Depot but all they had was SAE grade 8 not in metric tho...I refuse to pay the 30-60 bucks that these places i found want. they are just freaken bolts, somewhere there has to be a place I can go to find these at a reasonable price... thanks for any help oh and I am going with some shorty headers if that makes a difference
Trying to get thru my LS swap ![]() |
Re: Header bolts size
What I am finding it is an 8mm x 1.25 thread. Hit up lowes or home depot you should be able to get them for a couple bucks.
#3 | |
meowMEOWmeowMEOW
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Sep 2005
I ordered mine from advance auto from Dorman products they are coated in something g that makes them look gold and is suppose to help them from seizeing in the heads and breaking
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Thanks guys for the help, going to check ace hardware, I didn't even think about them. Truckdude I have antiseize in a tube but thanks for the advice
Thanks that's what I was thinking but wasn't sure
meowMEOWmeowMEOW
Isn't the goldish color zinc?
Fabricate till you "puke"
I have a set left over, from a set of Hooker shorties....I used studs/ nuts on mine? Yours for the mail price, but it may take a few days, from my spot in Illinois, to yours in Cali? They are black oxide bolts, nothing special....if you want them,I don't need anything , but the mail charge
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#9 | |
meowMEOWmeowMEOW
![]() ![]() ![]() ![]() ![]() ![]() Now, ![]()
#10 | |
#13 |
meowMEOWmeowMEOW
Damn, just like in real life, people figure Ima just show up with everything.
Oil....its not just for your motor anymore... ![]()
#14 |
meowMEOWmeowMEOW
btw you can get a set of 12,16 or 17 in that size from Afco for under $10
#15 | ||
Thanks everyone now that's one less thing I need to worry about
#16 | |
#17 | |
#18 |
I can't seem to catch a break with this build I was getting so close to start up now this... Found one in each head as I was mounting my headers...pulled both heads and now in machine shop to have them pulled and since its in there doing a complete valve job as well
#19 |
meowMEOWmeowMEOW
Ya, thats what anti-seize was for...but most of us forget it. Thats also why the stud-style replacement has gotten more popular, as its much less likely to sheer at the nut.
#20 | |
#21 |
yeah I've had like 4 now in the coupla motors ive messed with
they're pretty dang easy to get out at least |
#22 |
![]() Join Date: Oct 2013
I went with stainless bolts. not as common, as they're metric, but they are out there and should hold up pretty good.
#23 |
![]() Join Date: Dec 2012
Anybody know where to get a good set of studs for the manifolds, I cant seem to find many of them.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#24 |
meowMEOWmeowMEOW
#25 |
Thank you sir, that is exactly what I was looking for.
