Old 06-10-2014, 01:54 AM   #1
ml68nova
ml68nova's Avatar
dually disc brake rotor swap for a 72 c30.
I have a 72 c30 dually. Can 8 lug non dually front rotors be used on the dually spindles? Would the caliper placement be the same?
Thanks, Mark
ml68nova is offline   Reply With Quote
Old 06-10-2014, 09:41 AM   #2
Wrenchbender Ret
Re: dually disc brake rotor swap for a 72 c30.
I believe it can be done but you would have to use wheels for single rear wheels. The spaceing is all different.
Wrenchbender Ret is offline   Reply With Quote
Old 06-10-2014, 11:13 AM   #3
kwmech
Thanks, Mark
No, the caliper mount and I believe the thickness of the rotor is different. The biggest issue is the caliper mounting. Swapping the spindle is super easy though
