Old 06-10-2014, 10:04 AM   #1
CATCHALLBLUE
CATCHALLBLUE's Avatar
carb help....
howdy,
Im in the process of taking apart my Rochester Monojet carb. for cleaning/rebuild. What i can't figure out is how to take off the connector rods. They each have a pin on the ends. Thanks for any insights/techniques.
CATCHALLBLUE is offline   Reply With Quote
Old 06-10-2014, 02:19 PM   #2
Wrenchbender Ret
Re: carb help....
You have already removed the screw. Pry off the plate & the rod will come out of the power piston rod. Then turn it enough to remove the rod from the accel pump lever.
Wrenchbender Ret is offline   Reply With Quote
Old 06-10-2014, 03:35 PM   #3
CATCHALLBLUE
Re: carb help....
Thanks for the response. Looking at it im not sure what you meant by "pry off the plate".
Old 06-10-2014, 03:39 PM   #4
CATCHALLBLUE
Re: carb help....
AHHH ! just put some elbow grease on it and the plate popped off thank you!
Old 06-10-2014, 03:41 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: carb help....
The goofy "heart" shaped plate that the rod goes into. Put a flat blade screwdriver between it and the carb body and give a little twist/pry. It will come right off the shaft. Once you get it off the shaft, everything else will be self explanatary to remove the rods.
Gary
EDIT: I see you got it done while I was posting. Great!
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
