06-10-2014, 12:50 PM | #1 |
windshield frame rust
i got a small line of rust around the windshield frame on my panel i was thinking of spot/plug welding the damage shut should i do this or some other method feel free to give your idea's / input also post pic's if you can to show what you did thanks much
06-10-2014, 02:43 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: windshield frame rust
1st of all, put up some pictures of the damage. 2nd I highly doubt you could successfully weld rust holes due to contamination alone. 3rd it may work better for you to replace that portion, hence the reason for the pix
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
