Searching for a swb frame
Hey guys, I have a perfect 1967 cab and front end that I want use on a swb frame. What year frames will fit without mods?
#2 | |
The Older Generation
Re: Searching for a swb frame
Any '67-'72 short frame will work. You might check the classifieds on here or post a wanted to buy on craigslist in your area. You can't post a wanted to buy on here unless you are a premium member but if you find someone that has one on the parts forum for sale you can purchase it. LockDoc
![]() Join Date: Dec 2013
use searchtempest.com to search all the craigslist ads across the entire US , just type in your zip and what your looking for and it will bring up every ad starting with those closest to you first !
Thanks guys, there are plenty of frames and rollers in my area just wanted to make sure the 67 cab would fit without modifications.
![]() Join Date: Aug 2008
Imo 71-72 are best if you want one already equipped with disc brakes. They are getting more and more scarce though.Last one I did was a 69. I swapped the 5 lug rear axle & front crossmember out of a 71lwb I had. You can also use 73-87 crossmembers with slight mods
