meowMEOWmeowMEOW
A quick note on Fuel Pressure.
Seems like about 60+% of the swaps that don't fire first-time have issues with fuel pressure. Thanks to LittleVictories for the fitting; I put together a few small videos on installing the Fuel Pressure gauge on the LS rails, and modding your engine cover to fit. Eliminating the FP guessing-game goes a long way.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: A quick note on Fuel Pressure.
cool thread man, never seen ya before, i expected you to be some old fat balding guys lol
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#3 | |
meowMEOWmeowMEOW
![]() Between the people involved with my projects; 4 people all under 29, more than 40 years in the performance and racing industries.
Ya man...and in your parents basement lol
![]() Join Date: Dec 2012
Nice video and an easy enough mod. Should be a staple for all future LS swappers. Thanks br3w.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
![]() Join Date: Mar 2011
Thanks for the video's, nice work...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Certified BFH Operator
Add to LS FAQs Sticky!!!!
Nicely done Br3w!
- 1969 swb C/10 fleetside -LSx swap and Resto in progress LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay... ![]() -1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle |
I've been running one since day one of my swap that was two years ago this is a good idea my cover is different though nice work on yours. Not trying to hijack your thread.
![]() Join Date: Apr 2005
Nice job J!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
meowMEOWmeowMEOW
Yea thats nice! what about bleeding the system for returnless?
meowMEOWmeowMEOW
Got me there....what about it? I've never bled a fuel rail, the pressure from the pump would force any air through the rail and *burp* it during startup. The only time I've ever had an issue with air in fuel lines was from the pump pickup being in the wrong point, or a leak somewhere causing air infiltration.
Made me google it too, couldn't find any commonplace issues with air in the line, nor anything about bleeding the sytem (aside from tapping the schroeder valve to check pressure). Maybe someone else can chime in here.
#13 |
I had an experience once with a 2004 vette. Just built a new 414 stroker and installed it. Fired the car up and the whole passenger bank was not firing. Chased my tail on that one checking everything. Went to pull the fuel rail off and psssss huge burst of air blows out on the passenger side. Hit the key to make sure the rail wasnt clogged, put it back together and it fired right up ran like a champ. Ended up woth 559/525 na to the tires on that car. Craziest thing I have ever seen!!!
#14 | |
meowMEOWmeowMEOW
One yall engineers in here needs to explain how the fluid can do this to me, cuz my brain refuses to see how this would happen.
#15 |
I just upgraded my 67 camaro to a fast 92/92 setup yesterday. Initial fuel pressure was 40ish until I cracked the aft cap on the billet rails and boom, shot up to 50 plus. I guess the question is before I get the 5.3 going in the c10 is where all do the air bubbles hide. Gonna try some more to bleed out the camaro today, my c10 still a month or so from start up but the same principle applies. Air compresses and liquids don't, lest not much. For those running return style shouldn't be a prob I'd think.
#16 |
meowMEOWmeowMEOW
This whole "air in the fuel rail" thing is just fishy to me. I've been around these things enough that I feel like if it were common (or even commonly discussed), I would have heard/read/written/seen the issue...which up until this thread, I really never have.
Yes, air can get into the fuel system from the pump end, or from a damaged line getting air into the system; but that air would travel (by weight and force) to the high point in the system, which would be the rail. When the air reaches the rail, the force of the fuel behind it would try to compress the air assuming the engine is OFF and all the injectors are closed, creating a sealed situation in which the air had nowhere to go. The second the engine starts, that pressurized air would be forced out the injector nozzle. Usually, when air DOES get into the system, the motor might sputter or cough for a second and go slightly lean, since the air was being expelled with the fuel into the chamber. There is no GM procedure for bleeding air from the system, its a self remedying problem. If this wasn't the case, imagine this scenario; your driving home, tank on E. You take a sharp corner to make a yellow, the pickup loses fuel and sucks air/aerated fuel into the lines....which would mean that you had introduced air into the system, and now needed to bleed the air back out. It would be unacceptable from an engineering standpoint. My .04 cents
#17 |
Great idea.
#18 | |
#19 |
Nice walk through Vid man. Thanks for the shout out
1967 C10 SWB 6.8L/4L80 |
#20 |
Old member
Hawk's put mine on the passenger side of the fuel rail. For what reason I'm not sure other than if it had a obstruction in that side fuel rail it would be noticed. I guess to you know you have complete fuel pressure to the whole system with it mounted on the passenger side.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#21 | |
#22 |
Hawk's link - Andy
Wonder if it depresses the schrader valve or if you remove the core... Price is right. |
#23 |
that is a pretty slick fix for guys with stock fuel rails
#24 |
I have similar to what andy has it an aeroquip 2242-2-4s fitting and a summit gauge. I did have to remove the schrader valve.
