Old 06-10-2014, 06:21 PM   #1
Mammoth
Question Questions on my 454
Hello. New member, I'm working on my 78 chevy k10 shortbed. Had a 350 with a automatic and the full time 4wd t.case. Putting in a decent 454 out of a 77 suburban and a muncie 465, and an np205 transfercase. Also had a 87 c10 doner truck pulled the hydro clutch and housing off. Im just freshening up my 454, seals gaskets, Etc. Im replacing the timing gears and the sets I keep getting are smaller!! The crankshaft gear bore no where near big enough to go on. Autozone stumped, napa said its a newer motor. IDK. Block numbers 361959 which is 73-85 cars and trucks, nothing special. Any help here? aftermarket crank maybe? I'm stumped.
Then after some research I've found out I cant use the SBC clutch, need a BBC because it externally balanced flywheel. It seems like a pain, but the 350 took a ****, and the tranny was on its last leg too. So it is my cheapest way out and think it gonna be awesome. Any help or ideas would be appreciated, I'm mechanically inclined, but mostly work on atvs and motor cycles. First time doing this type of swap.
Mammoth is offline   Reply With Quote
Old 06-10-2014, 07:06 PM   #2
Eug396
Eug396's Avatar
Re: Questions on my 454
I'm not sure what to tell you on the crank but if you need some help with the engine numbers, this is a good reference site. http://www.nastyz28.com/decode.php It covers everything, heads, block, cam, all of it. I recently refreshed my BBC too. I didn't have any problems with the timing gears installation. Almost sounds like they gave you the wrong part. May try looking up the part number yourself and seeing if it matches. Sounds like it will be a fun project for you though! I wish you the best!
Eug396 is offline   Reply With Quote
Old 06-10-2014, 08:34 PM   #3
geezer#99
geezer#99's Avatar
Mortec says you have a 73 to 90 454.
http://www.mortec.com/bbc.htm
What's the pad in front of the pass head have on it. Suffix code will narrow it down.
Old 06-11-2014, 09:01 AM   #4
cr92
i would be interested in the 87 hydro clutch assembly if you wanted to part with it
87 chev r10 SWB
cr92 is offline   Reply With Quote
