Old 06-11-2014, 01:31 PM   #1
heel97
rear suspension 64
Hey, I am working on a 64 chevy C10 rear end that is causing a little trouble. The shock mount crossmember has rusted through right at the spot the coil spring bolts through. I have been looking for a replacement crossmember, but the only thing I can find is the tubular one the cpp sales. I wanted to see if anyone knew if this would work as a replacement. The truck is at stock height and was not planning to upgrade at this time with any of the other tubular rear parts. Thanks for any help you have.
heel97 is offline   Reply With Quote
Old 06-11-2014, 04:13 PM   #2
forestb
forestb's Avatar
Re: rear suspension 64
I am sorry I am confused by what you mean when you say "shock mount crossmember". But that might just be me. If so ignore this post.
forestb is offline   Reply With Quote
Old 06-11-2014, 04:25 PM   #3
1963c-10
1963c-10's Avatar
I believe the lower mounts are just riveted in. I'd find a replacement off the forum classified section or hit the local yard up and score one.
Which side is it on that's causing the issue? I can check and see if I have one kicking around.
Also...check ECE...I know they make them. Heres a pic of a 67-72 frame which is almost the same as the 63-66 frame. Pic of the ECE mount
Link to ECE: http://www.earlyclassic.com/home.aspx
They are around $60 and sell them for stock shocks and lowered shocks Part #912-8000
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-11-2014, 05:38 PM   #4
heel97
Sorry if I hammered this pic posting, but tried to post pic showing the damage to the crossmember. It is on the left side of truck. Plan is to replace springs, shocks, and bushings on rear end, but figured this needed to be replaced. Thanks for the pic above, that is right on with what I am looking at (but in much better shape). Thanks for your help. Will check out the ads and other links.
Old 06-11-2014, 07:48 PM   #5
donthekawguy
donthekawguy's Avatar
If you pull the bed off it will make life a lot easier. You can make a cross member and just bolt it on were the rivets go for the stock one.
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-11-2014, 08:25 PM   #6
heel97
Thanks for the info. Found one today from ECE so now the fun begins I guess. Will get it in garage this weekend and get bed off to ease the break down and start getting things cleaned up under there. Thanks again for the help.
Old 06-12-2014, 09:01 AM   #7
1963c-10
1963c-10's Avatar
I head down to Wilmington all the time to fish off the piers....we'll have to link up one day!!
Old 07-06-2014, 12:34 AM   #8
heel97
I hit the piers any chance I get for some fishing. when I was at Ft. Bragg would make the drive back home every weekend to get some real fishing in. Thanks again for help.
