Old 06-11-2014, 01:45 PM   #1
btgrande
69 Short step front alignment specs
At last I have finished my project.
It has ECE 4/6 static drop, wheels are 255/50/17, motor is TPI
I mailed Mark at ECE, to ask for a good alignment, since my truck was all over the road. Well, I had mounted the centerlink backwards...
Othervice I shoud go with factory alignment specifications.
Does anyone know what those are?
Thanks,
btgrande is offline   Reply With Quote
Old 06-11-2014, 01:52 PM   #2
leftybass209
leftybass209's Avatar
Re: 69 Short step front alignment specs
The thing I've never understood about the "specs" is that if it's still wrong for whatever reas9n the alignment shop or whoever does it will change it till it's right anyways. You can check the pdf service manuals. Do a search here and that should yield your answers. Best of luck!
leftybass209 is offline   Reply With Quote
Old 06-11-2014, 04:32 PM   #3
btgrande
When I reinstalled the centerlink correctly, I altered the toe in setting...
Here in Norway most of the alignment shop has never adjusted an old pickup.
i was thinking, what caster/camber/toe-in angels will work on my setup?
I'll try to do a search, thanks!
Old 06-11-2014, 04:38 PM   #4
Lee H
Lee H's Avatar
BEMERDOC did a great write up. Not sure how to embed a threat. Look up his tread regarding "magic button".
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-12-2014, 09:56 AM   #5
btgrande
Thanks, thats a great tread, guess we will be able to get it to handle well.
BTW -you have a very nice truck!
BT
