Radiator hoses.
Just finishing up the 383 install in my 62. Anyone know of a Napa or Goodyear part number for upper and lower hoses? Thanks.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Radiator hoses.
Are you using an original style radiator? Does the engine have the short water pump like it should, or is it a long water pump?
Re: Radiator hoses.
I'm running a long pump and aluminum radiator with oem dimentions.
Re: Radiator hoses.
Maybe the ones Brothers Truck sells will work.
1965 C10 Project |
Re: Radiator hoses.
Re: Radiator hoses.
For my 64 C10 with a 350 long pump I used an upper molded hose for a 1966 C10 with a 327 for the lower hose I used a Gates #20694 molded radiator hose. I had to trim a little off the water pump side. I believe the hose is for a 67 or 68 C10 with factory A/C.
Re: Radiator hoses.
What direction should the water necks face on these trucks?
Re: Radiator hoses.
Re: Radiator hoses.
I can't say how it's supposed to be from the factory in 1964 but the one I have that I bought the upper hose to fit a 66 with a 327 is angled upward maybe 30 - 40 degrees or so and points pretty much straight ahead towards the radiator.
60-66 Nut
Re: Radiator hoses.
Those only work with the '63-'66 style radiators.
Re: Radiator hoses.
so 60-62 rads are diff then 63-66?
Re: Radiator hoses.
yes the top hose is in the center, not on the side.
1961 chevy K10 my build is------------61K10 build |
#13 |
Re: Radiator hoses.
I just took a wire and bent it to the shape I need then went to carquest and matched up the hose. Top hose was easy. Bottom hose had to be trimmed on both ends.
#14 |
Re: Radiator hoses.
