Old 06-12-2014, 07:00 AM   #1
farmallboy15
70 4x4 disc conv, which brake lines to use
Hi,
I have a 1970 GMC k2500. I've converted the front dana 44 over to disc brakes. I've also added the power booster kit. Now I am needing to get new brake lines.
I know the lines to the master are going to be different but are the rest of the bends between a 70 and a 71 pretty close? What about diameters.
Bottom line what makes the two brake line sets different?
Thanks ahead of time!
farmallboy15 is offline   Reply With Quote
Old 06-12-2014, 03:22 PM   #2
seattle gmc
seattle gmc's Avatar
Re: 70 4x4 disc conv, which brake lines to use
How did you do your conversion? Im interested in doing this some day to mine.
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 06-12-2014, 03:25 PM   #3
farmallboy15
I bought a later dana 44. I believe mine was from a 75. Then I switched the axle shafts and everything from the knuckles out.
Old 06-12-2014, 03:53 PM   #4
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Do you have open or closed knuckle D44? If open knuckle, then you don't need to swap axles. I have a '70 open knuckle design, which (from what I understand) makes this easier.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 06-13-2014, 10:51 AM   #5
seattle gmc
I would like to go to disc up front, but i don't want to swap out the axle to do so. Im not sure if i have a closed or opened knuckle, how do i tell the difference, i can take pics if you guys could tell me. Too bad this thread didn't pop up last week as my truck was up on blocks with all the wheels off. Sorry for butting into your thread farmallboy, hopefully you get the answer you are looking for.
