Exhaust system recomendations
72 Blazer 4x4 cst stock 350 engine with stock ramhorn manifolds. What do you guys recomend I have installed? I am thinking 2.5" pipe dual exhaust exit just behind the rear tires. Not sure on the mufflers? Should I take it to Midas or a mom&pop shop?
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
Re: Exhaust system recomendations
mom and pop shop.
![]() Join Date: Jun 2000
If the Blazer is driven without a top, you may want to consider having a downturn on the ends as that may help prevent exhaust getting sucked into the back.
Well I am going with 2.25" pipe with Magnaflow mufflers dual exhaust exit out just behind my tires with chrome tips.
#7 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Not sure what you mean Pete? I want a nice clean installation that is professionally built I took it to the Mom and Pop shop.
Carpe manana
From GM our K5's were all single exhaust and the 4wd's have an exhaust bracket that attaches to the frame rail as shown here: http://67-72chevytrucks.com/vboard/s...d.php?t=567957
I made use of another 4wd hanger bracket to make the dual exhaust setup appear to be "stock". The opposite frame rail already already has the holes to bolt the second hanger right up. You can see the opposing brackets attached to my K20 frame below - they're anterior to the rear cab support.
