Old 06-12-2014, 12:49 PM   #1
66pnl
66pnl's Avatar
olds v8
I know the olds diesel was available in the late 70's trucks but was the gas version also an option. I was told by a couple differant guys that their trucks came from the factory with the gas motors. Were they bs'n me or was it an option. I did some searching but didn't come up with any thing.
66pnl is offline   Reply With Quote
Old 06-12-2014, 01:29 PM   #2
Old Truck Man
Old Truck Man's Avatar
Re: olds v8
As far as I know there where not any factory gas oldsmobile engines factory installed in the square cabs. Now in the late fifties there where Pontiac ,Buick & a few Oldsmobile engines installed in GM trucks. I once installed a 260 gas olds into a 77 GMC Pk. it got good fuel economy but didn't have much power.
Old Truck Man is offline   Reply With Quote
Old 06-12-2014, 06:29 PM   #3
naphtali5725
naphtali5725's Avatar
Re: olds v8
I don't think there were ever gas olds engines in them...
but you can put olds engines in them pretty easy... i'm putting a 455 in my 86...
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 06-12-2014, 07:19 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
Re: olds v8
It didn't come from the factory that way, but it did come from the dealer that way. What happened very often was that the original Olds diesel was so troublesome, dealers would replace them under warranty with an Olds gas engine because it was a direct replacement.
Old 06-12-2014, 09:15 PM   #5
mrolds88
Re: olds v8
Externally the Olds diesel was identical to the Olds small block gas engines. None of the trucks were Olds gas from the factory. The good part is that everything from the 260 to the 455 will bolt in.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 06-12-2014, 09:20 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: olds v8
Exactly. There's a pile of trucks running around with 307 Olds engines due to diesel failures back down the line.
Old 06-13-2014, 12:49 AM   #7
mrolds88
Re: olds v8
The Olds diesels started in 78 or 79. If they were replaced under warranty they had to be replaced with a 260, 350 or 403. It would have probably been a 350. Because the only Olds engine with less power than the 350 diesel could have only been the 260. The later 350 diesels were better. They were marked DX on the side of the block and had less failures. They could have been replaced with the 307's under warranty.
93 K2500 xcab 6.5TD
Old 06-13-2014, 12:56 AM   #8
66pnl
66pnl's Avatar
Re: olds v8
Right on, thanks for all the info guys.
Old 06-13-2014, 05:56 AM   #9
S10Fan
Old Heap Driver
Re: olds v8
I had an Olds 98 with a diesel in the late 70's, you don't want one of those motors. I believe those era diesel motors would fail as a boat anchor.
As mentioned above though, I've seen a couple squares with Olds (gas) motors, none were factory according to the owners.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
