06-12-2014, 02:10 PM | #1 |
How to brace cab when installing 1 piece floor
I'm about to install a 1 piece floor pan with all the mounting. Whats the best way to brace the cab to keep the integrity of the cab? Thanks for all the help in advance.
Thanks! |
06-12-2014, 09:28 PM | #2 | |
The Older Generation
Re: How to brace cab when installing 1 piece floor
I'm presuming this is a pickup truck? The reason I ask is that if it is you accidently posted it in the Suburbans and Panel trucks Forum. If that is the case I can move it for you. Let me know.... LockDoc
06-12-2014, 11:46 PM | #3 |
Whoops! Yes your right. If appreciate if you could move it.
Thanks! |
06-13-2014, 09:40 AM | #4 |
I cross brace the cab with 3/4 inch conduit, front to back in the door openings, and across the cab, side to side, when doing any major surgery on them. You can kind of see the conduit bracing in this thread when Ron and I replaced the floor pan and part of the rear panel in his '69 4x4.... http://67-72chevytrucks.com/vboard/s...d.php?t=490272 LockDoc
06-13-2014, 09:56 AM | #5 |
I am running the braces across the door and one cross-brace.
This is the main area you need to support to ensure that the doors fit correctly when the new floor is welded in. |
06-13-2014, 10:01 AM | #6 |
Ok, great. Now, I am putting new cab corners, rocker panels, firewall, and the floor. Is there a particular order that is best. I was thinking about doing the cab corners first, then the rocker panels (Just tacking to cab since new floor not in just yet), then the firewall, and lastly the floor. What do yall think?
06-14-2014, 08:00 PM | #7 | |
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
06-14-2014, 08:25 PM | #8 | |
Here are a couple of threads on the subject.... http://67-72chevytrucks.com/vboard/s...d.php?t=574886 http://67-72chevytrucks.com/vboard/s...d.php?t=271066 LockDoc
06-14-2014, 11:55 PM | #9 |
Here is what I did. Not the best pictures, but maybe they will help.
06-17-2014, 10:10 AM | #10 |
Thanks for the input guys. Quick question regarding the cab corners.....if Im putting in a new floor should I put the cab corners in before the new floor? Isnt the back of the cab corners tac welded to the back of the floor?
06-17-2014, 10:15 AM | #11 |
I would wait to do the cab corners until you are finished with the floor. They should be plug welded to the rear support brace.
06-17-2014, 07:52 PM | #12 |
I don't mean to hijack the thread, but I'm doing the same project and didn't think I should start a new thread.
Does the one piece floor need to be installed from the bottom? Like have the new floor bolted to the frame then drop the cab onto it? The one piece floor is heavy and large, and I can't see getting it into the door opening to drop it down into place
06-19-2014, 07:12 PM | #13 |
Flameout I did mine with the cab on its back. You don't need to drop it on a mounted floor.
06-19-2014, 08:55 PM | #14 | |
