Old 06-12-2014, 04:41 PM   #1
Liftedchevrolet
Chevy not starting
I have a 72 chevy k10 lifted with a 402 big block in it. It was running fine but the other day I went to start it and it kicked and back fired. Which is usually on the first crank. But then everything went dead and it won't crank and all the electronics went out. The radio wont turn on and the horn wont work. Any ideas?
Liftedchevrolet is offline   Reply With Quote
Old 06-12-2014, 04:51 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Chevy not starting
How does the fuse box look? Any fuseable links on the starter wite or adjoining? How about the negative cable?
1967custom
michael bustamante is offline   Reply With Quote
Old 06-12-2014, 04:56 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
There is a fuseable link that comes off of the positive battery terminal and goes to a "hot post" on the passenger side fender under the hood. Check the fuse in that link.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-12-2014, 05:02 PM   #4
Liftedchevrolet
Would that cause the radio and all other electronics to not work. Cause it dosnt even click like its a dead battery.
Old 06-12-2014, 06:21 PM   #5
jjzepplin
jjzepplin's Avatar
Yep. The small cable coming off the + side of the battery goes to the truck and the big battery cable just goes to the starter. Follow that small cable and look for issues and bad fusible links etc. Fusible links have much softer wire inside and funny looking clear cylinders around a section in the middle. Sometime hard to tell if blown but will feel limp like the wire inside is broken.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-13-2014, 10:31 AM   #6
Liftedchevrolet
I checked and the fuse on the fender looks to be on good shape. Any other ideas?
Old 06-13-2014, 10:46 AM   #7
jjzepplin
jjzepplin's Avatar
Which fuse? What did it look like. Take a pic and we could help more. If the fuse looks stock with a rubber housing-that one is just for the amp gauge on the dash. The positive smaller wire should go directly to a junction block on the fender.
Old 06-13-2014, 11:15 AM   #8
Liftedchevrolet
This is the fuse i found. It looks to be intact. Where you talking about a different one.
Old 06-13-2014, 11:28 AM   #9
jjzepplin
jjzepplin's Avatar
Never seen that one before. Looks after market. Take a pic of your battery cables if you can.
Old 06-13-2014, 11:52 AM   #10
Liftedchevrolet
here is the battery wires. I bought it from a neighbor and he bought it from a guy in utah who did a bunch of custom work on it.
Old 06-13-2014, 11:53 AM   #11
Liftedchevrolet
Here is what the truck looks like.
Old 06-13-2014, 11:56 AM   #12
jjzepplin
jjzepplin's Avatar
Nice looking truck!
Follow that smaller red wire connected to the pos. battery cable. That is power to the rest of your truck.
Old 06-13-2014, 12:02 PM   #13
Liftedchevrolet
It goes into the fuse I showed and across to the opposite side of the truck. Would that also make the engine not turn over?
Old 06-13-2014, 12:09 PM   #14
jjzepplin
jjzepplin's Avatar
Something here is not right or modified in some way. The original fusible link must have fried and then they put in a fuse. But it should still be wired to a distribution block on the inner fender just to the left of your battery. Is there a positive wire going to that block? Is the block still there? I am thinking you need to start checking for voltage first from your battery then to the other side of that fuse and then to the dist. block on the fender.
Old 06-13-2014, 12:13 PM   #15
Liftedchevrolet
I will check can you post a picture of an example of what the distributor block looks like.
Old 06-13-2014, 12:21 PM   #16
jjzepplin
jjzepplin's Avatar
If it wasn't raining flood style right now I would go outside and take a pic.
It screws to your fender and just has a few positive wires (smaller than battery cables) all bolted to one small bolt insulated by the black plastic.
Take a pic of your inner fender on your negative side of your batt.
Old 06-13-2014, 12:36 PM   #17
Liftedchevrolet
is this it?
Old 06-13-2014, 12:55 PM   #18
jjzepplin
jjzepplin's Avatar
Yep. Check for voltage to that post.
Old 06-13-2014, 01:38 PM   #19
Liftedchevrolet
Before I checked the distributor block I put the ends of the multimeter on the battery and only got .002 volts. Could the battery be so dead that it dosnt even click the starter anymore.
Old 06-13-2014, 06:27 PM   #20
jjzepplin
jjzepplin's Avatar
Yep-simply a dead battery. CHARGE!
Old 06-14-2014, 04:06 PM   #21
Liftedchevrolet
I charged it and it was still dead. So I tried to jump it. When we hooked it up whichever truck was hooked on last sparked like crazy. I got the battery tested and it's crap. But it still shouldn't spark when hooked up to jump it should it?
Old 06-14-2014, 06:16 PM   #22
litew8
litew8's Avatar
If you tried charging it and it failed to hold a charge, no need trying to jump start it. How long have you been driving it, before the battery up and died?
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 06-14-2014, 06:31 PM   #23
Liftedchevrolet
I just bought it from my neighbor. And drove it across the street and have started it up a couple of times since. But it still shouldn't spark when jumped. Should it? Do you think the grounds could be bad?
Old 06-14-2014, 07:03 PM   #24
litew8
litew8's Avatar
Some spark should be ok. Sounds like there may be a preexisting condition (e.g. it isn't charging the battery), or, it's a coincidence the battery up and died the minute you drove it across the street. It'd be a good idea to check all wires for good connections and ground straps (not rusty) - for peace of mind when you install the new battery. While you're at it, check the alternator.
Old 06-14-2014, 07:39 PM   #25
Liftedchevrolet
It didn't die right when I brought it over. It had bin there for about a week. And it sparks a kit and smokes a lot. And if you connected it to the second truck last those connections would spark and burn.
